Thread: Pump Down Bad Cap
    May 2012
    Allentown, PA
    219
    Pump Down Bad Cap
    I have a hayward pump and motor the capacitor is bad it is 35uf 370VAC/B
    part number 325p356h37n36n4x where can I get a new one from. I have a good cap from a dehumidifier that is rated at 35uf 270VAC will that work temporarily? Thanks
    21,500 Gallon Vinyl liner pool Eastern Pennsylvania
    Hayward 2 HP pump 2" Pvc pipes Full Sun Pool
    Hayward sand filter, Compupool CPSC 48 SWG
    12mil solar cover and reel
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Pump Down Bad Cap
    Motor shop or Amazon: Amazon.com: 35uf 370vac capacitor
    Mark
    May 2012
    Allentown, PA
    219
    Thanks for the help. I ended up putting in my dehumidifier cap that I had laying around and the pump fired right up. I ordering a new one through Amazon thanks for the link. I would have just got one from the motor shop, but they are not open on weekends and with prime shipping it is cheaper and faster to use Amazon. For anyone reading this post, the symptoms were that the breaker tripped on the panel because the motor was humming. I separated the pump and motor to make sure nothing was clogged and that the motor was free spinning. I kept the motor disconnected and added power and the motor hummed, so I gave it a spin by hand and it started running fine, so I determined the capacitor was bad (it was also slightly bulged). Thanks for the help.
