Results 1 to 7 of 7
Thread: Rust stain on new plaster
    May 2015
    Fullerton, CA
    635
    Might be the wrong place, appears wife jumped in with a metal hair clip last night this moring i found it but the is a nickle sized light brown stop on the floor. The pool brush did not help alot. Other suggestions?
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    OTPirate's Avatar
    Oct 2013
    Creedmoor, NC
    1,150
    Re: Rust stain on new plaster
    Try rubbing it with a little Vitamin C pill
    May 2015
    Fullerton, CA
    635
    Does it matter if it new pebble plaster, 10 days old
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    The vitamin c pill should take the stain out without harming the plaster. Just gently rub it on the stain.
    Love TFP? Become a
    TFP Supporter!
    May 2015
    Fullerton, CA
    635
    Thanks, i think i got all of it out. Cant see it anymore but the sun is out now. Will check on it at dusk. It was in the deep end so that was quite a pain. Are muliple treatments sometimes needed? Again i went down with a mask and since there are some light brown or tan pebbles in the mix i do know if its all gone. The spot that i saw from the deck is gone.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Sometimes a second treatment is needed. If you can't see it I wouldn't worry about it. It won't hurt anything.
    May 2015
    Fullerton, CA
    635
    Thx for the help, i was thinking i would have to drain and acid wash to get it out. Just want to catch a break on this pool, lol.
    Oh and wife got much grief over this, i told her no jewlery of any kind in the pool before this happened, so she really learned here. Now i need to have a metal detector before anybody goes in. New proceedure is to check bottom of pool before going in the house for the night.
    *edit, its gone. I went in the pool with a mask and snorkel, i can't see a trace of it, that vitamin C worked magic.
