Thread: Is Cal Hypo with bleach
    Jul 2012
    Richmond, Va.
    43
    Are all these chemicals compatible in AG Pol.
    For 20 years no problems using the pucks in my floating dispenser. Then couple years with stablizer going to high. Did not make since because my neighbor still had no problem with the pucks. But I was getting more shade from a tree.
    Anyway I was forced to switch. So went to adding bleach everyother day and just one puck in the dispenser once a week. Plan seems to be working good the past 2 years.
    But hard to buy so much bleach when I shock the pool. So my question is would it be ok to use the 1 lb bags super shock just when I shock. They are 68% Calcium Hypochlorite
    Thanks for all the help here
    6014 gallons aprx
    cartridge type filter
    summer escapes pool above ground metal frame
    SFS1000 SkimmerPlus filter pump with GFCI=1,500 GPH
    install date: 6-1-12
    Dec 2014
    Santa Ana, CA
    523
    Re: Is Cal Hypo with bleach
    Quote Originally Posted by rayh78 View Post
    acceptable use of solid form of chlorine depends on how much water you replace from time to time (open/close, other reasons). Those events would bring CYA down so you could use solid chlorine longer. OTOH I found this mixed approach too complicated to bother. I see couple other options for you:
    - find local pool store and buy their 12.5% liquid chlorine. My local store 'rents' out bottles along with 4 bottle case so I bring empty ones back and they sell me filled ones charging only for LC. I paid for bottles/case once at the beginning. The cases are heavy as each contains four 1 gal chlorine jugs but I don't have to recycle bleach bottles on regular basis.
    - get yourself SWG which will produce chlorine for you. Very convenient but high upfront cost and additional piece of equipment to maintain.
    The decision depends a lot on your situation.
    One more thing: Cal Hypo does not mix with pucks in the same container and leads to explosion. It will bring your CH up and depending on your water it could be OK or not- the same problem as with CYA/pucks.
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
    Jan 2012
    'burbs of Augusta, Georgia
    7,368
    +1 what he said
    Yip
