Thread: New to pools, first pool and wanting to get it right
    May 2016
    San Antonio, TX
    7
    Greetings all,
    I posted this on my thread, but wanted to put it here too.
    I did my first numbers today and got:
    FC 10
    PH 7.8
    TA 90
    CH ??? I think I remember 260 or so
    CYA sub 30, as my tester doesn't go below 30
    Temp 86
    I have the Taylor 2006 and started running the numbers today and keeping them on Excel.
    My question is: Where do I start to correct the numbers?
    16K gal IG w/ SPA, Wet edge technology pebble plaster, pentair Intelliflo variable speed pump, Pentair Tagelus High Rate Sand filter, Pentair easy touch control system, Pentair Kreepy Krauly Legend cleaning robot
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: New to pools, first pool and wanting to get it right
    PH is most important and should be maintained daily. The rest just keep in line with the mfg recommended start up process. Order isn't important.
    It is important for you to let folks know that this is new plaster.
    Do some reading here, ABCs of Pool Water Chemistry
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Monitor pH every day (or twice daily!) and keep the level down using Muratic acid. Keep chlorine in range but the other figures - at least initially - are less critical. Keeping you pH in line is key to preventing scale from your curing pool
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
