Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Fighting constant high PH
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    Seems like every 5-7 days my PH is going above 8.0,, the red is at or above the highest red mark on my TF-100 ph test tube.
    I add the appropriate amount of muratic acid (according to pool school),, check it the next day and its down around 7.2-7.4. I have 3 returns that I had pointed a bit high, and I adjusted those a few weeks ago so there is no more bubbling at the return outlet, just a bit of a swirl at the top of the water line.
    I do have an overpowered 1.5hp pump, that I was hoping to not have to replace. I might just have too much water going through the returns? If I lean up against the returns, its pretty powerful.
    I just checked my ph and its 8.0+ plus again. I can control my returns via jandy valve, should I turn them down or do you think something else is at issue here?
    My chlorine, cya and other readings are all within check,, just the PH keeps going up.
    In-ground block / vinyl liner 33' x 22' x 5',, approx 25k gals
    Cartridge Filter
    Floor drains, 2 skimmers, 3 return lines (2" plumbing ultra-flex PVC)
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Fighting constant high PH
    What is your TA? High TA can push PH up.
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    Quote Originally Posted by pooldv View Post
    TA looks good, I just tested it 90-100.
    Cartridge Filter
    JoyfulNoise's Avatar
    May 2015
    13,231
    That's too high then. Try dropping it to below 80ppm (maybe try 70ppm). Then, do a very careful experiment after you drop TA to 70ppm - drop the pH to 7.4 and then everyday measure the pH until it gets to 8.0. Let's see what your acid demand looks like after doing that.
    Matt
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    Ok, so according to pool school, the only way I see to drop TA is lowering PH to 7.0-7.2 using acid. Wait a day, recheck PH & TA then. Then aerate to get PH back up to 7.5 (or so). Is this what you are recommending I do?
    Cartridge Filter
    Jun 2011
    Long Beach, CA
    2,790
    Repeat that process until the TA is 70ppm. What are you using for aeration?
    May 2015
    13,231
    No need to wait a day between dropping th pH and aerating. Drop the pH to 7.0-7.2 using Pool Math with your current TA value and then measure your new pH and TA after about an hour or so. Then aerate until the pH cones up to 7.6 and repeat the process. For most average sized pools, the addition of acid to drop the pH usually consumes about 10ppm TA. So you'll likely need a few acid/aeration cycles.
    Matt
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    Ok, I'll give it a shot.
    I had planned on aerating with my return jets, pointing them upwards. Is there something else that would work?
    Cartridge Filter
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Some people build fountains on one or more of their return jets. The other option you have is just give it time. Every time your pH naturally rises, hit it with acid to bring it down to 7.0-7.2. Then wait, when the pH naturally rises to 7.8, hit it again with acid. The TA will slowly come down to the point the pH will stabilize. My pool actually likes the TA down in the 50-60 range.
    Support the site
    May 2015
    13,231
    Quote Originally Posted by tim5055 View Post
    Tim,
    Sometimes waiting until you hit 7.8 before lowering again is counter-productive especially if the fill water has high TA and evaporation rates are high. The rise in pH is not linear between 7.2 and 7.8. It's very fast from 7.2 to about 7.5 (a few days) and then it begins to stall between 7.6 and 7.8 and come sometimes take a week or more to fully rise in that range particularly when yo start to reach your target TA value. So cycling the acid addition/aeration between 7.2 and 7.6 works a little faster and that is why I wrote it that way in my post.
    Matt
    Matt
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    OK thanks both of you,, I don't think I've ever had the PH to 7.0, so I added a little more acid as it was only 7.2 a few minutes ago. I'll go out and check in 45 minutes and start aerating (assuming it hits 7.0). I'll check it later tonight, once it hits 7.8,, I'll add more acid,, and repeat until TA gets to 60 or so.
    Cartridge Filter
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yes, you are just like many of us unfortunately. I have high TA/pH fill water and its just a battle we will have forever. It will slow much more once you use th advice given and get your pool TA down. TA 70 is my absolute high ceiling but my high Calcium level permits me to take mine even lower, which I try to do as a regular maintenance routine.
    Essential Links:
    BobbyR's Avatar
    Jun 2013
    Toronto, Ont
    142
    I'm having the exact same problem right now in my hot tub. It's an acid eater.
    Lagoon 40x22, Vinyl, 27,000 gal, 1HP WhisperFlo Pump, Pentair 60 gpm Sand filter, Hayward Brominator (used for chlorine pucks only when away), Rheem gas heater, Dolphin M4 Robot
    Waterfall on separate dedicated pump
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    Well I've tried the lower PH,, aerate,, add more PH,, aerate,, but my TA stays at about 100. I've been lowering the PH to about 7.0,, then aerate for about 6-8 hrs,, the PH gets up around 7.6 and I hit it with more muratic acid, taking it back down to 7.0,, then repeat the aerate. I've done this 3 times so far.
    I did add about 2 inches of water, so that might have disrupted things (increased TA with the new water?).
    Cartridge Filter
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,256
    My PH constantly drifted up and every 4 days I had to lower from 7.8 to around 7.4. The TA was at 130 (at it's peak). Even at 90, I had to lower the TA. Not until the TA reached 70, did the PH stabilize. My pool found the perfect combination. My pool had to do with rotating heads that break the surface water. I took advantage of all the snow and rain water this winter, which lowered my TA, etc.
    Good luck and keep us posted!
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    360
    Test your fill water. Well water especially can have high TA (mine is 220.) That adds a bit of complexity to your process.
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    FInally,, tested TA this morning twice - down around 70ppm. PH at 7.2,, FC about 4,, I think my pool is as balanced as it's ever been and good thing its suppose to be 90+ and high humidity today and tomorrow.
    Cartridge Filter
    May 2015
    13,231
    Quote Originally Posted by dw9000 View Post
    Ok. Now try to test your pH daily or every other day. The point is to see how long it takes to get to a pH above 7.8. The initial rise from 7.2 to 7.5 will probably be quick (a few days). But the rise between 7.6 and 7.8 should be slower.
    Matt
    Jul 2015
    Tempe, AZ
    194
    I'm another person whose pool's pH is much more stable with a TA around 50 or 60. I also had to learn to not try to keep it at 7.5. It stays between 7.6 & 7.8 for a long time. I have high TA fill water so it's a constant battle during the summer here.
    John - 16,000 gallon | in ground | pebble | Triton II sand filter | TF100 | speedstir | Hayward Phoenix 2x
  20. Back To Top    #20
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    This takes a lot of time sometimes. It takes me at least a couple of weeks of frequent additions to get mine from 90s-100s down to 50-60 ranges.
    Essential Links:
