Thread: Fix polaris 360 or replace it?
    Oct 2013
    Fort Worth, Texas
    19
    Our Polaris 360 has not been working so we took it to the local pool store to get it fixed. I knew that there was a hole in one of the hoses and a few of the connectors were leaking, so I figured we'd just have to replace the whole hose. They said they could do a water test to figure out exactly which parts were failing and needed replacing. Well, apparently it's pretty extensive. I don't have the paper in front of me that lists everything, but needless to say it was quite a few parts. So he said we have two choices: -1-we could buy the kit and just replace the parts that were broken. However, there were additional parts that weren't included in the kit, so those would also have to be purchased separately. Or -2-just buy a new cleaner. He said the price difference would be roughly $300 for the kit + additional parts vs roughly $600 to replace it. So do y'all think it makes more sense to just buy a whole new cleaner that would come with a warranty and less hassle or save the money and just get the kit? And regardless of which route I go, should I purchase it myself online/eBay, etc. and get a better price as opposed to the local pool store? Thanks for the help!
    ~20,000 gallon, plaster, sand filter, not currently sure of the pump size or flow rate of the filter, Forth Worth, Texas
    **clearly I'm a newbie, so please forgive my ignorance--I will update as I find out more about the equipment that we have**
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,265
    Re: Fix polaris 360 or replace it?
    This is mostly just a bump for your thread and maybe someone with expertise will see it. I've heard more like $200 for the rebuild kits. In the meantime, this video might be interesting: Polaris 360, 380 Belt Replacement - YouTube
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
