Results 1 to 18 of 18
Thread: DFW Builders
    Jun 2016
    Fort Worth, TX
    19
    DFW Builders
    Can anyone here share your experiences with these three builders, Klapprodt, Puryear and Pulliam? Any comments about these builders at all would be greatly appreciated as I'm trying to narrow down to one.
    Limited lifetime warranty excluding soil movement, war and act of God vs 3 years warranty no question ask. Which is better? Can everything bad happen in the first 3 years or usually later?
    Thank you!!!
    Aug 2014
    Houston tx
    2,525
    Re: DFW Builders
    There are a lot of DFW pool builds here so I'm sure someone will be along shortly to help you out. If you have pics of your proposed pool from those builders, please post them! We love pics!
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Jun 2016
    Fort Worth, TX
    19
    Re: DFW Builders
    bdrex28's Avatar
    Jun 2016
    Frisco, TX
    247
    Re: DFW Builders
    Quote Originally Posted by duylinh View Post
    Thank you!!!
    I'm in Frisco so more the Dallas side obviously, but those are not three builders I'm familiar with. As someone else said; there are so many builders in DFW!
    I like the lifetime warranty, did any of them include sprinkler re-route, fence repair and several palates of sod? Also, check on plumbing warranties too.
    Brian (Frisco, TX)
    2016 18,250 Gallon IG, Spa, Pentair Intelliflo VS, Pentair Master Temp 400k, , EastyTouch 8/ScreenLogic Surface: Pebblesheen Blue Surf with Abalone, Travertine Coping and Pavers. 3 LED in Pool 1 in Spa. New Frisco, TX Pool Build
    Aug 2014
    Houston tx
    2,525
    Re: DFW Builders
    As we all know, lifetime warranties are only as good as the company is in business...
    Marla
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,534
    Re: DFW Builders
    Duylinh,
    While I like the visual effect of the three rectangular boxes, near the house, to me I just don't think they are very practical. Whatever cleaner you get will not be able to run in-between them and I'm not sure you could even manually brush between them. Seems to me that you are paying for wasted space you could be swimming in.
    Jun 2016
    Fort Worth, TX
    19
    Re: DFW Builders
    Quote Originally Posted by Marlahoutex View Post
    True and so many restrictions so I'm not really sure what exactly are covered. Can the pool crack without soil movement?
    Quote Originally Posted by Jimrahbe View Post
    Duylinh,
    Thank you and I agree with you but my husband is in love with the stepping stones so he knows that he needs to clean the spaces manually. There is a 10 inches gap between the steps so I think we can clean them. Plus the bubblers on the same playform should help with the water movement.
    Jun 2016
    Fort Worth, TX
    19
    Re: DFW Builders
    Quote Originally Posted by bdrex28 View Post
    All of them include clean up, grading and top soil, sprinkler reroute and Fence but no sod.
    May 2016
    fort worth, tx
    123
    Re: DFW Builders
    Everyone we know that has gone through Pulliam and dealt with Bart has been extremely satisfied. Past that, opinions vary. We tried to use Pulliam, but got hooked up with another guy that didn't really click for us, so we went another direction. If I had a do over, I would have insisted we dealt with Bart. Did I mention you have to deal with Bart?
    Construction began 5/2016. IGF pool. 41' x 21'. Jandy DEV60, Jandy 2hp 2sp pump, Polaris 280 Black Max, Rainbow 320 chlorinator, Jandy JXI 400, Jandy iAqualink, Jandy LED's. 2'x2'x10' rock weeping wall. Dive rock. Tile/Plaster: NPT Silverstone AquaMarine Decking: Stained Stamped Concrete/Stonescapes Aqua Blue with glass beads and abalone. http://www.troublefreepool.com/threa...-Fort-Worth-TX
    Jun 2016
    Fort Worth, TX
    19
    Re: DFW Builders
    Quote Originally Posted by Technobuyer View Post
    We didn't get Bart and I'm not too fond of my sales guy either but I didn't want to dismiss a good builder just because of the sales person. So hard to make a decision since I don't know anyone that owned a pool in Dallas. We moved from California and summer here is awful.
    bdrex28's Avatar
    Jun 2016
    Frisco, TX
    247
    Re: DFW Builders
    The sad part is this has been a fairly mild summer! Usually hit the high heat combined with our humidity, much earlier than we did this year.
    Brian (Frisco, TX)
    May 2015
    Fort Worth, TX
    25
    Re: DFW Builders
    All three builders have built in our neighborhood and are popular builders in the Fort Worth area. We have talked to all three and are preparing to sign with Klapprodt this month. Puryear refused to warranty items if we went SWG (pushed ozone). Pulliam pushed soil injection treatment (not sold on this) especially in our area as rock is hit about 6ft down where the injection takes place.
    Good luck deciding!!! We are nervous as heck and researching as much as possible as a FTPO. This forum has been very educational and helpful in answering questions to give me more power in negotiating the things we want.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,580
    Re: DFW Builders
    Check on some past pools they have built. How are they holding up? How is the company to work with AFTER the last check is cashed?
    Jun 2016
    Fort Worth, TX
    19
    Re: DFW Builders
    Quote Originally Posted by hawks View Post
    Hawks - Thank you and good luck on your build. We are nervous too, first pool and all.
    Thanks. Just a question for you on SWG, both of our surrounding walls are flagstone (in the pictures, looks like brick but it is flagstone), those are the community walls and not ours. Do we need to seal them if we go with salt system?
    Re: DFW Builders
    My brother in law used Klapprodt. Very happy with them and they have taken care of him on some warranty items (acid washing to get better finish, skimmer leak, etc.).
    We are in Prosper, on the other side of the Metroplex, and used Claffey. They are based in Southlake. I can't recommend them highly enough. We built in 2011 and they are still honoring warranty work for things like Jandy Lights that have a known problem from the factory, etc.
    Great to work with!
    40K Gallon gunite chlorine diving pool with spa, Blue Granite finish
    Jandy Watercolors LED lights (2 pool, 1 spa)
    Jandy equipment with RS8 controller
    Borates added in the form of Borax and Acid.
    Prosper Texas
    May 2015
    Fort Worth, TX
    25
    Re: DFW Builders
    From all the research I've done, I think that wall will be just fine with no sealer.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: DFW Builders
    I agree completely.
    Jun 2016
    Fort Worth, TX
    19
    Re: DFW Builders
    Thank you all!
