Results 1 to 16 of 16
Thread: OCLT test
    Aug 2015
    Greenwood Lake , ny
    27
    OCLT test
    Will the test be valid if the pool heater was left on all night?
    30,000 gal inground, vinyl, Hayward sand filter, 1 hp pump, Well water make up, Raypak heater w/bypass, TF100 testing kit.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: OCLT test
    should not be a problem
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: OCLT test
    That should not have an effect, as far as I know. As long as the pump was running at least30 minutes before you test, and you don't have any tablets or an SWG running, you should be good.
    Aug 2015
    Greenwood Lake , ny
    27
    Re: OCLT test
    Was at 17 ppm last night and 15 this morning with a cya of 35. I didn't put any chlorine in the pool all day while I was gone because I wanted people to be able to swim tomorrow. Just tested it at 6:00PM and I get a reading of 10 ppm. Pool is crystal clear. I had an algae problem beginning of the week kept it at slam level for a few days (worked great) and now I'm getting nervous. Using non stabilized chlorine sticks in the skimmer basket all summer. Just put a couple in. Could I be in trouble? Don't like the Chlorine drop off.
    domct203's Avatar
    Jun 2015
    CT
    3,589
    Re: OCLT test
    Quote Originally Posted by Oscar477 View Post
    If you lost 2ppm of FC overnight then your SLAM is not complete. What was your CC level? A SLAM is not a one or two day event, shock level must be held until you pass all three criteria to complete the SLAM.
    Pool School - SLAM - Shock Level And Maintain
    As far as I know, all forms of solid chlorine are stabilized, either with CYA (Trichlor/Dichlor) which is very common, or calcium, but that is usually in a granular form (cal-hypo).
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Aug 2015
    Greenwood Lake , ny
    27
    Re: OCLT test
    Dom,
    This is what I use. It says in their literature that it is unstablized. Look for the bucket with the Yellow top. Poolife.com
    poolife® Active Cleaning® Caplets Chlorinator
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: OCLT test
    Dom,
    It says they are calcium hypochlorite on their website.
    Aug 2015
    Greenwood Lake , ny
    27
    Re: OCLT test
    Sorry but I don't know what calcium hypochlorite is. Is this product bad? BTW the store where I bought it says it can't be used in my Chlorinator only the skimmer. Been using it all summer to keep CYA level down. It's a stick that goes in solid and than gets thick gooy.
    domct203's Avatar
    Jun 2015
    CT
    3,589
    Re: OCLT test
    Calcium hypochlorite (cal-hypo) is chlorine stabilized with calcium, adding calcium to your pool with each use (around 0.7ppm of CH for every 1ppm of FC, depending on CH%).
    What is your pool's current CH level?
    Dom
    Dom - TFP Guide
    Aug 2015
    Greenwood Lake , ny
    27
    Re: OCLT test
    Just leaving house. Will check all Chemical levels when I get back.
    Thanks for help Dom.
    Aug 2015
    Greenwood Lake , ny
    27
    Re: OCLT test
    Here are my numbers from test just now.
    PH-7.5
    FC-14
    cc-.5
    TC-14.5
    CH-275
    TA-70
    CYA- 30-35
    Have 4 adults coming in an hour should I let them in my Pool? LOL Pool is cyrstal clear
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: OCLT test
    Hose em off first!
    Aug 2015
    Greenwood Lake , ny
    27
    Re: OCLT test
    Oh boy I just don't want to make them sick.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    Re: OCLT test
    Ocsar they will be fine. CH will not hurt a person BUT it will lead to problems over time with your pool and heater.
    Please look at this chart. As you can see you are getting close to the top for CH. Please also check your heater and see what it needs for CH and go from there.
    DFW, TX
    24,497
    Re: OCLT test
    I was kidding! Hose them off first so they don't mess up your perfect pool.
    Numbers are fine for swimming.
    It is safe to swim when
    FC is above minimum for your CYA so the pool is properly sanitized and safe to swim. Check, won't make them sick
    FC is below shock level for your CYA, FC/CYA Chart
    PH Is between 7.2 and 7.8
    Water is clear
    As long as FC is above minimum for your CYA your pool is properly sanitized and you won't make people sick.
    Aug 2015
    Greenwood Lake , ny
    27
    Re: OCLT test
    Thanks, people are running for the pool
