- Jan 4, 2016
- 5,290
- Plaster
Thanks so much for 39 responses Here's a report in the next two posts.
Category 1. Peristaltic Pumps (28 Stenner, 2 custom)
All use drop-based testing with pump timing dialed in to meet FC need
Three members have tried FC/CYA below 7.5%; 27 stay above 7.5%
One member stays in bottom 1/3 of FC range; most of those who mentioned FC and CYA ppm use 10% as their target
Pump run time (hrs/day) | Doser run time (mins/day) | Dosing approach | Day or night | Remarks |
24 | 84 | 14 doses | day | pump on low speed |
7 | 75 | 3 doses | day | 40 GPM pool pump flow |
6 | same as pump | as pump runs | day | |
8 | same as pump | all at once | day | stay closer to 10%; 3rd year with Stenner; only maint. is annual tube replacement |
5 | 22 | 2 doses | day | target 5 FC for 40 CYA |
12 | 33 | 3 doses | day | 1100 RPM then 2600 for solar; 5-6 FC |
6 | 30 | 2 doses | both | one dose day, one dose night; stays at target |
8 | 38 | spread out | day | only one month running so far |
4 | 90 | spread out | both | uses target FC |
5.5 | 50 | spread out | both | |
11 | same as pump | spread out | day | 7 FC @ 60 CYA; working CYA down over time |
12 | 107 | 2 doses | day | 7 FC @ 70 CYA |
5 | 60 | 2 doses | both | 3 pump cycles; 5 FC @ 50 CYA; ~60 oz. per day |
7 | 50 | spread out | day | |
24 | 150 | 3 cycles of 50 min | day | 4 FC @ 50 CYA |
6.5 | 36 | 2 doses | both | 75% at 9pm; the rest at 11am adjusted per need; stays in bottom 1/3 of range; 6 hrs 1200 RPM; 30 mins 2000 RPM |
4 | 17 | all at once | night | 40 GPD pump |
4 | 70 | all at once | day | uses less than 7.5% FC/CYA which occurs at end of cycle before dose; 45MPHP10; experimenting with temp and solar radiation as inputs to determine run time |
6 | every 15 minutes | 24 doses | day | 4 FC @ 40 CYA |
8 | 75 | 2 doses | both | 4 x 2hr pump cycles; Stenner pump time adjusted on second dose per testing; 7-10 FC; only algae was when tank ran out and if it's rainy and windy while away for more than a week |
8 | 23 to 46 | both | night | 23 mins (one dose) weekdays, 46 mins (two doses) weekends |
10 | 120 | all at once | evening | 3 gal Stenner, 100 PSI; 32 oz of 10% reduced as weather cools off; aims for 1 ppm FC above target |
5 | 67 | 2 doses | both | use water temp to set dosing, checked with drop-based testing and adjusted weekly |
24 | 90 | 3 to 4 doses | both | set up so each 30 min cycle adds 1 ppm FC, 3-4 cycles per day; 32 ounces per cycle; tried running it lower than 7.5% but experienced some algae, so now staying at target |
24 | 270 | all at once | night | 3 GPD pump with 55 gal in-ground cistern for chlorinating liquid; circulation at 30 GPM; Stenner runs 8pm to 12:30am; drops to 5 FC at 65 CYA just before dosing |
6 | 7.5 | 2 doses 10 mins apart | night | Beta DR2000 peristaltic pump; uses less than 7.5% with no algae issues |
2.5 | 23 | all at once | night | these are winter numbers; summer is 82 minutes; keeps FC a bit above minimum |
6 | same as pump | spread out | both | Stenner 85MHP5; keeps FC at target (5 ppm for 40 ppm CYA) |
4 | 60 | spread out | day | keeps FC >7.5% of CYA; sets to 10 (full) to stop clicking, click happens when it stops |
15 | 15 to 30 | all at once | evening | Stenner 10 gpd single speed on timer; 15 gal tank; 2-speed pump on low; keeps FC at >7.5% |
