Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: New Pool in Arizona
    May 2016
    Gilbert/AZ
    16
    New Pool in Arizona
    Tired of the AZ heat and no water! Growing up in Florida it was nice to cool off at the beaches, rivers and lakes. But living in the desert now for almost two decades I figure its time to add some water into the mix!
    Starting this post to keep track of the weekly pool progress. Here are the picture's so far:
    Computer modeling:
    20K gallon IG Ultra Poz plaster, AutoPilot SWG.
    DE Quad filter, Pentair pump.
    May 2016
    Gilbert/AZ
    16
    Re: New Pool in Arizona
    Finally got the pre-grade done and the layout below:
    May 2016
    Gilbert/AZ
    16
    The hole is a lot bigger then I thought it was going to be!
    May 2015
    Land O Lakes, FL
    527
    Great design and it sure feels great once they finally get started.
    Just a note on your equipment. I don't have any personal experience, but i have read many times that the ozone / frog systems are very much frowned upon. Might recommended that you do some research on those before you turn them on.
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    spoonman's Avatar
    Jun 2016
    Peoria, AZ
    242
    Great design, Yabruf. Love the way the pool wraps around your patio.
    Also, nice to see some new Arizona/PHX members.
    14x28 IG Rounded Rectangle, 6" aqua tile, White plaster, Gray Acrylic deck, 4' Baja Step (18"), aerator jets, 3-step InterFab SS Ladder, Pentair Intelliflo VS Pump, Pentair TR100C Sand Filter, Stenner Econ E10T2A (chlorine), K-2006, Zodiac Baracuda G3 pool cleaner
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Look at that beautiful Arizona soil!
    Dolphin E10 Cleaning Robot.
    Jan 2014
    Buckeye AZ
    807
    must only be a 3-foot to the property line restriction where you are....
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    spoonman's Avatar
    Jun 2016
    Peoria, AZ
    242
    ^ Yeah, that's nice. It's 5' where I am...darn HOA (or city...well, I prefer to blame the HOA)
    Jan 2016
    Mesa, Az
    541
    Mesa is 4' setback to water's edge from property line. I just went 4' from the inside of my fence since I didn't have time to dig up the irons.
    Sep 2015
    Tucson, Arizona
    86
    Our HOA was much more restrictive on setbacks than the Town of Marana, and both were easy to get variances from when our layout and dig ended up a little over the lines.
    I don't know your intended use for the pool, if you have kids, or how deep your deep-end is, but I would consider adding some additional bench areas, especially in the deeper end.
    -- Edit --
    I see that your pool is 8' in the deepest end, so I would definitely consider tucking in some more benches to make the deep end more usable. I know pool builders like to charge an arm&leg for benches, but it shouldn't add much to the actual costs except for the added shotcrete
    Owner Build. 32x16, with 6x8 raised spa. Broke ground April 1, 2016, swimming July 18. Pentair Intelliflo VS + Whisperflo for Water features; Clean & Clear Filter 420; Master Temp Heater 400k BTU; Intellibrite 120V pool and spa lights; Regular ol' plaster.
    Jul 2016
    Rancho Cucamonga, CA
    231
    5' to the water here, it was the thing the city inspector was most concerned about (as in what he checked first).
    Nice clean hole! Must've been a breeze to dig. The hole is currently ~2ft wider (and ~1ft deeper) than it will end up being so as to put the shell in etc.
    I like the inset step/seat in the deep end, breaks up the design etc.
    What type of fruit tree is that in the corner? Some sort of stone fruit?
    Pool-15x31', Spa-7x9', depth 3.5-6', HP Pentair Whisper Flow pump/motor, Intelliflo 8-160, 4-to-8 speed, Pentair 320 Clean and Clear capacity filter (upgraded to 400,000BTU stackless heater). Stacked stone- Autumn Rose Classic, tile- Ridgeline Blue Slate, coping- Turning Leaf Quartzite. Start date 7/12/16! Progress thread
    May 2016
    Gilbert/AZ
    16
    Spoonman- Thanks! Yeah we initially were going to extend the shallow end from 32' to 36' long but decided to extend the deep end so it comes in closer to the house.
    BuckeyeChris- Yep, here in Gilbert its 3' from the wall and 5' from any house or structure.
    GeoSage- Yeah that backhoe tore through that dirt quite easily! I used to live in AJ and after about 1.5' I hit caliche rock when digging a koi pond. Much nicer dirt when your not so close to the mountains! Oh and that is a grapefruit tree. Had to trim it up quite a bit to make way for the PB.
    May 2016
    Gilbert/AZ
    16
    Quote Originally Posted by azdesertpool View Post
    -- Edit --
    AZdesertpool,
    Yeah the pool builder had benches in our first design. A long one extending from the shallow to the deep end and one at the deep end protruding out into the pool. After thinking it over I wondered why would I dig a pool just to fill it back in with a bunch of cement blocks? When I was a kid there were never any benches, grotto's or beach entries. I just wanted as much water to play in as possible.
    But I guess that depends on what the primary use of the pool is going to be. For us the main purpose is exercise ie swimming laps, teaching my kids the three survival strokes(Breast stroke, back stroke, and side stroke), and deep water training with weights. It will have a volley ball net but the sides will alternate deep and shallow to keep it fair. I grew up in Florida and when I was in the water I wanted to be fully submerged. I think its odd when people get benches that have you sit in a foot of water. I will use the bath tub for that....lol
    Below pics show the long bench. The recessed bench in the deep end was protruding but we changed it to recessed and made the deep end wider.
    May 2016
    Gilbert/AZ
    16
    Plumbing stage done!
    Rebar check!
    May 2016
    Gilbert/AZ
    16
    Can finally see it taking shape! Shot Crete done. Been watering it down every few hours day and night. PB told me I only had to water it 2-3 times, only during daylight hours but I don't want to risk any cracking!
    Have read to many posts on here where people have small cracks that they were told was normal. I am going on my fifth day of watering around the clock and I have seen no cracks.
    May 2016
    Gilbert/AZ
    16
    Just had the tile installed today. Initially thought it was the wrong color but it was actually the reflection of the sun that was making the copper streaks look white!
    The tile in the pool still has film of grout dust on it so its hard to see the the full color.
    Jun 2016
    Chandler/AZ
    16
    What a coincidence, we chose the same waterline tile! I'm sure once they are cleaned up the metallic streaks will really pop.
    Looking good so far!
    spoonman's Avatar
    Jun 2016
    Peoria, AZ
    242
    Very nice. How deep is your pool? Looks like about 7 or 8'.
    May 2016
    Gilbert/AZ
    16
    Yep right at 8' deep end and 3.5" at the shallow.
  20. Back To Top    #20
    May 2016
    Gilbert/AZ
    16
    Yesterday they started the decking and completed some more today. Now we have to wait for the long labor day weekend to be over before they continue working on it.
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
