Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Foreclosure swamp is almost there.... New pool owner/Slam content.
    Aug 2016
    egg harbor twsp
    8
    Hello Guys.
    I have a nearly complete swamp to pool success story, but I have a few questions. I'll post my latest numbers tomorrow because my notes are not here but they are within spec.Here's the background:
    I bought a foreclosure with a pool that was neglected for years and lost it's cover. I hired a pool professional to open it.
    He did a great job of cleaning the debris and scrubbing the pool. He pulled out enough leaves to fill a Mini Cooper!
    The problem was that nearly four weeks later my water was still green. It was better than the swamp black color that it was, but it still had algae.
    The pool guy said it was fine.... I disagreed so I searched and found your forum.After some reading, I quizzed him about the relationship between CYA and clorine. He didn't have a clue. He was also using test strips, so...I bought a Tayor K 2006 test kit and began.
    My CYA was high at 100, my FC low at about 6 ppm, and high CC. I drained some of the water and got the CYA down to 90. (in retrospect I guess that I should have gone further but this was all new to me.) I read about slamming, looked at the CYA/shock ratio, and added LOTS of 12.5% liquid chlorine to get the pool up to the recommended level of 35 PPM which scared the heck out of me !
    I continued the process for four days until my water was clear (but still a bit turbid) and the CC test was _almost_ clear without the first drop of reagent, so safe to say below .5 CC. I replaced more water during those 4 days by back washing and last night my CYA was 70.00 with FC of 26 PPM.
    So here's the question. I can't do an overnight loss test due to scheduling. Over a 19 hour time period that included a full day of intense sun, My chlorine had dropped from 26 to 16 ppm. We would like to use the pool over the weekend. If I let my FC drop and maintain at 8ppm, am I looking for trouble, or was that much chlorine demand/loss normal for a 19 hour time period with intense sun?
    AuquaBat
    30,000 Gallon in ground pool, vinyl liner, Pentair legend cleaner with booster pump, Sand filter, more details to follow!
    Aug 2014
    Northern IL
    4,615
    Re: Foreclosure swamp is almost there.... New pool owner/Slam content.
    Not normal. Continue the slam! However, you can swim as long as you can see a swimmer in trouble and the FC is below slam level. Just get back to the slam after swimming!
    Aug 2016
    egg harbor twsp
    8
    Quote Originally Posted by MarianParoo View Post
    OK, Thanks!
    I can see swimmers clearly. the pool is 40 feet long. standing on the ground above the water at the shallow end, I can see my two main drains at the far end in eight feet of water. It's just a bit turbid. I want it to be drinking water clear!
    Will the pool survive two days of 8ppm, or should I slam each night?
    I hate to have the kids swim with high chlorine levels. How high is safe at a CYA of 70?
    Thanks.
    Aug 2014
    Northern IL
    4,615
    Anything below 28ppm, which is your slam level. It really is okay to swim with "high" FC as long as you are in line with your CYA. Maintain 28 (or a tad higher) as often as you can. Then swim when it drops to 27-. When you're done swimming, boost it back up.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Yes, it is safe to swim with FC between minimum and shock level for your CYA, FC/CYA Chart. We swam every day last summer while SLAMing with FC 25 to 28 and CYA at 70. Nobody even noticed except the guy with the test kit.
    FC at shock level for a given CYA level is less harsh than FC at 1 ppm in a pool with no CYA.
    Aug 2016
    egg harbor twsp
    8
    You guys are the best. Thank you!
    I'll post some numbers and maybe some pictures when I get a chance.
    BTW, am I loosing accuracy by using the 10 mil line when the kit dictates that I can?
    I already had to buy extra reagent for chlorine and CYA.
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    352
    Your CYA will not change unless you do a water change or your FC goes so far negative that the algae starts eating it.
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    Aug 2014
    Northern IL
    4,615
    Yes, you are losing some accuracy with the 10ml, however we are comfy with that. Accuracy is usually within +/- 1 drop. It is also important to make sure you sample is 10ml and not 11 or 9.
    Aug 2016
    egg harbor twsp
    8
    Thank you for the info.
    I did not slam last night. This evening my water was nearly crystal clear. Here are the test results:
    FC 9 ppm
    CC .2
    CYA 60 ( I am getting more critical/Better with this test and I am guessing that is why I drifted)
    Ph7.2
    TA 130
    I put a few stabilized chlorine pucks in the skimmer. I'm off tomorrow. After swimming, I'm going to give the pool steps and jets a good scrubbing and I'll brush the pool really well. I'll test again of course. As long a cc is .2 and not zero I'm inclined to keep slamming. Any thoughts?
    Thanks!
    Aug 2014
    Northern IL
    4,615
    Why did you choose to add pucks to your skimmer instead of just using liquid chlorine? They will just add more CYA.
    If it were my pool, I would take them out right away. Then I would get a good FC reading an hour later and perform an OCLT.
    Aug 2016
    egg harbor twsp
    8
    I put them in because the outside temps have been in the high 90's and very sunny ( it's the UV that eats chlorine, correct?). I work on call, and some shifts that would have possibly kept me at work for an extended period came up. The kids were in the pool at the time, and I need to leave immediately for work. I decided that it was the easiest way to add some chlorine with the kids being in the pool and without me being there for an extended period.
    I'll be at the pool later today. I'll pull them and test the water. tonight I'll make changes accordingly.
    Thanks for the input
    Aug 2014
    Northern IL
    4,615
    Chlorine gets burned off by UV. It also gets used up fighting algae, sweat, pee, bacteria, etc.
    I understand now why you added the pucks. Maybe next time you can have someone throw some chlorine in when the kids get out for a break.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,390
    You have done a great job so far! I can't wait to see pictures!
    I really think you should look into a SWG (Salt Water Generator). It will help you maintain the FC with little to no input from you.........With your work I think this would work great for you. I am posting a link for you to read over and start learning about them:
    Pool School - Salt Water Chlorine Generators
    There is a whole section on here about SWG and such. Feel free to read over it and ask any questions you might have.
    I am also going to share a set of links I put together for new pool owners. It is a lot of info. to take it a bite at a time.
    Print these out:
    Bookmark these:
    http://www.troublefreepool.com/calc.html
    Make sure to ask any and all questions you might have no matter how small! We have all been where you are at one point.
    Aug 2016
    egg harbor twsp
    8
    Thank you so much for the links. I've been reading as much as I can with the time I have. I've learned so much from this forum. The pool has been great! no one can believe it's the same pool, including myself
    I'll post pics when I get a chance. This is my busy season, and I'm renovating a former foreclosure as well so remember that patience is a virtue
    Best regards,
    The 'Bat man.
    Aug 2014
    Northern IL
    4,615
    Looking forward to the pics! Good to hear it's going well!
    Jul 2012
    Tallahassee, FL
    30,390
    So long as things are going good with the pool I am happy! Keep learning! Ask questions as needed and share pics when you can!
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Some pre measured wate bottles or 2 liter bottles filled with bleach for someone to add while your away could help.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Aug 2016
    egg harbor twsp
    8
    Black Lagoon
    3 Days into SLAM You can see the main drain at eight feet deep
    Wala !!
    I hadn't yet cut the grass because I wanted to keep the contaminants (clippings) out.
    It's even clearer now that it's had time to filter properly. I truly could not have done this without you guys!
    Thanks again,
    The 'BatMan
    Aug 2014
    Northern IL
    4,615
    That is super! Thanks for the update.
  20. Back To Top    #20
    Jul 2012
    Tallahassee, FL
    30,390
    SWEET! That is great!!! Someone knows how to clear a pool!
