Thread: Average Cya additions
    Dec 2015
    Newington, Connecticut
    113
    Since the start of the season after today I've added 4lbs of granular stabilizer via the sock method to maintain 30 to 50 ppm. Just wondering from the seasoned pool owners if this sounds pretty average usage?
    16'x34' Kidney 17000 Gallon IG Vinyl liner. Pentair IntelliXF vs pump, Sta-Rite System 3 DE filter. Liquidator, TF-100 Test kit w/ speed stir. Aqua Comfort heat pump, Dolphin Apollo robot, clear solar cover, stamped concrete deck.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Average Cya additions
    CYA normally decays at a rate of 2-3 ppm per month, sometimes up to 5 ppm with high FC or high temps. If FC drops below minimum for your CYA, FC/CYA Chart, sometimes bacteria can consume it. Of course, rain, splash out or overflow will lower your cya. I had to add some CYA in the spring and again a week or so ago.
