Thread: Proper Order of operation
    Aug 2016
    Merrick NY
    10
    I Just finished my first water test TF-100 and enjoyed every minute of it. I'm just not sure what to do first. Below are my results:
    FC - 4
    TC - 4
    PH - 7.2
    TA - 80
    CH - 250
    CYA - 68
    Salt - 3000
    Borate - 30
    Please help, I've read all of Pool School, but I think I am on information overload!
    PS, my water looks clear, just noticed some small green spots in the corners of my steps in the shallow end (where my Dolphin M400 couldn't get to, so I just brushed it up).
    33k gal, SWG vinyl IGP, free form lagoon, 8' deep end 4' shallow end, Pentair IntelliFlo VS 2hp, AutoPilot SWG, DE filter, Manifold with RC-35/22 cell, Pool Pilot Digital, Gas heater, waterfall, 7 wall returns, 2 bottom returns, 2 skimmer baskets
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    Re: Proper Order of operation
    According to your CYA results, you FC is too low.
    True L 45,000 gal Hayward IG vinyl pool. Hayward Tristar 2.40 THP; 1.5 FRHP/1.60 SF. Hayward Model # S310T2 Sand Filter. Aqua Rite T-15. Aqua Comfort 154,000 BTU Heat Pump. TF-100
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Congrats on the test kit. Numbers look good. Keep an eye on PH, it will probably climb. And keep FC above minimum at all times for your CYA, FC/CYA Chart.
    This is probably a handy page if you haven't found it, Pool School - Water Balance for SWGs
    Aug 2016
    Merrick NY
    10
    OK thanks, so just add a gallon of bleach? (as per the PoolMath calc) or do I add more salt and hit "boost" on the AutoPilot and let my SWG make the chlorine?
    Aug 2014
    Northern IL
    4,615
    Bleach is good.
    DFW, TX
    24,450
    Yes, +1 to bleach. No need to add salt unless the cell gives you a low salt error.
