Thread: Jandy Watercolor LED - intermittent
    Angry Jandy Watercolor LED - intermittent
    I have 2 large Jandy LED Watercolor lights in the pool. One works fine.
    The other light (in shallow end of pool) has something wrong. The light turned off (the deep-end light was still on). Then it turned on & dimmed until it went off again.
    Shut-off the power and took a look. The outer-most ring where the pilot-screw goes in can be pulled out.
    I'm thinking it may just mean that I have to align & tighten down the pilot screw because that is part of the grounding circuit, correct?
    The installation & operations manuals don't provide a lot of help.
    I would appreciate any guidance!
    33,000 Gallon vinyl liner pool, SWG, Cartridge filtration, newly built 2014
    33,000 gallon salt water freeform vinyl liner with concrete walls and waterfall
    Built in 2014
    Jandy PHPM 2.0 pump, Jandy CV460 cartridge filter, Jandy Aqua Pure PLC 1400 SWG
    Using the TF-100 test kit
    Apr 2015
    tucson, arizona
    1,121
    Re: Jandy Watercolor LED - intermittent
    Are these 120V or 12 V? Are they controlled by automation or manual?
    Apr 2013
    Sacramento, CA
    2,769
    Its probably a bad bulb or moisture in the fixture itself. It could be wiring but less likley.
    Do you have a multi meter?
    The ring is "connected" to the equipment ground only if the lights are 120 vac.
    I ended up calling my local pool service. They looked and said the light was defective & was probably covered under warranty.
    Built in 2014
