Thread: Problems with Lueders Coping
    Jun 2016
    Dallas,tx
    7
    I have a new pool being finished with Buff Limestone Lueders coping. The edge not adjacent to the decking has remained pristine. The edges alongside the concrete deck has become discolored and has pits with orange staining. PB tried to tell me this was normal but has replaced some. I asked about their being sealed as I thought this was going to take place and he reports this is NOT their norm to seal Is this correct? I have an Ozone chlorinated pool. Everything I read says lueders should be sealed. There have been many mistakes during the build process that has cost them money to fix along the way. I'm not sure if they are trying to get out of sealing due to an expense or if people really don't seal lueders. It is not specified in my contract.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Problems with Lueders Coping
    Welcome to TFP!
    Orange stains are usually iron and/or rust. Vit C will remove a rust stain. Stone is not normally sealed in pool builds, it is an extra service.
    Ozone doesn't chlorinate a pool. More here on that, Alternative sanitizers and pools--The Truth!!
    Jun 2016
    Dallas,tx
    7
    Thanks for the suggestion.. How would you recommend I apply? Because vit c is an acid, this won't damage the stone?
    Ozone doesn't chlorinate a pool. More here on that, Alternative sanitizers and pools--The Truth!![/QUOTE]
    DFW, TX
    24,497
    Vit C will not damage the stone. You can make a paste, let it sit for 5 or 10 minutes and hose it off. If it doesn't work try again and let it sit longer, it is ok to let it sit for a few hours if needed.
