Thread: Jandy Aquapure Problems
    Aug 2016
    Cantonment
    1
    Hello. I have an Aquapure system on my pool and its stopped working. its getting power and all the fuses are good but the only light on the panel is the power light and nothing is showing up on the display screen. we had a bad storm come through yesterday so im thinking it got struck by lightning but i need to know where to start to figure out what part/parts need to be replaced. really wanting to do this without having to call a service tech out as funds are tight. thanks for any and all help!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Jandy Aquapure Problems
    welcome to TFP
    Here is a manual http://www.zodiacpoolsystems.com/~/m...ABB0216B4.ashx
    It may be the motherboard but I am not sure how to test it to see if that is the problem.. from the manual you can buy the PCB board alone.. this may help some
    How to replace Jandy AquaPure 1400?
