Results 1 to 9 of 9
Thread: Pump won't run on high
    Aug 2016
    Newnan, GA
    6
    I'm having a similar issue. I have a AO Smith motor that when the pump is switched on it starts humming but won't spin. If I tap on the motor and starts spinning.
    Time to replace motor?
    "In every walk with nature one receives far more than he seeks" -John Muir
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Pump won't run on high
    Welcome to the forum!
    More than likely the start capacitor is bad.
    Mark
    Aug 2016
    Newnan, GA
    6
    Quote Originally Posted by mas985 View Post
    Is that part of the motor?
    This is the best picture I could get bring in the box.
    It is wired 110 now but I'm have a 220 gfci box installed by an electrician next week.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Yes, it is part of the motor. I think in that motor it is either in the hump on the casing if there is one, or in the back of the motor.
    Mark
    Aug 2016
    Newnan, GA
    6
    Ok great. I think I'll have the electrician look at when he is here next week.
    Do you think it's safe to run for now?
    mas985's Avatar
    Pleasanton, CA
    11,741
    Just one other thought. Those symptoms can also be for frozen bearings. After you hit the motor and it starts, if you shut it off and then turn back on, does it start on it's own then?
    Mark
    Aug 2016
    Newnan, GA
    6
    Yes. It seems to only not start after it has set for a few hours.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Ok, then that is probably the bearings. They can be replaced but you are probably better off with a new motor.
    Mark
    Aug 2016
    Newnan, GA
    6
    It's an 05' model and I'm sure it original pump. Pretty sure I'll just go with a motor.
