Thread: First Year Calcium question
    Aug 2016
    Seneca/MO
    2
    I am beginning to understand the basics ... Many Thanks to all of you and this site for its multitude of information. I live in the country with fields around and a pond not to far. I suffered a pretty bad frog attack earlier and had some troubles with algae. My mistake was not finding all of you and going to the pool store and almost paying for my pool again in chemicals with little results. I feel I have begun to get a handle on the algae but my alkalinity is 180 my ph is 7.4 and my pool is cloudy so much so I cant see the bottom. I do have low calcium 100. Can calcium levels cause cloudiness? 28 foot pool Sand filter. Be gentle on me this is my first post...
    The definition of Insanity is doing the same thing over and over and expecting a different result...
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Re: First Year Calcium question
    Welcome to TFP!
    No, calcium isn't causing your cloudiness. CH can cause cloudiness to when first added, but not ongoing. Your cloudiness is from algae and bacteria. This is how we kill algae and bacteria, SLAM.
    You will need a good test kit to perform the SLAM process. I use the TF-100 from TFTestkits.net. It is the best value, here's why, Pool School - Test Kits Compared
    Take a look at Pool School,
    ABCs of Pool Water Chemistry
    Add your pool info to you signature so that we can better help you. More here, Pool School - Read This BEFORE You Post
    Aug 2016
    Seneca/MO
    2
    Thanks for the quick reply. I will be ordering one of these tests kits next week. Is there anything I can do before hand?
    DFW, TX
    24,513
    Add your pool info to your signature, brush the pool daily, do some reading in Pool School and maintain FC at 3 ppm.
