Thread: New plaster job with streaks
    Aug 2016
    Phila, PA
    2
    I just got my plaster redone with QuartzScapes St Martin Shade (a dark color). About a week after brushing daily and balanced water, I've noticed white streaks in the pool the look like they are like water marks from before the pool was filled. I had it filled immediately (probably only 2 hours after the plaster was done). I know I should have waited after reading 6 hours is ideal. I also has rings where the pool water stopped between fills (despite having a hose running). The color also appears to have grayed / whitened a bit in the last week. Any ideas as to what is going on? It is hard to get a good pic that isn't all reflection due to the dark color.
    Thanks!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: New plaster job with streaks
    Welcome to TFP!
    I would contact your PB/plasterer first and NPT second to look at the pool.
    This might help diagnose it
    Diagnosing Pool Plaster Problems
    More info from NPT here on start up, maintenance and far
    FAQ | National Pool Tile Group
    Care and Maintenance | National Pool Tile Group
    JenniferJuniper2's Avatar
    Mar 2015
    sacramento, ca
    137
    Pics?
    I don't have any good advice but we recently re-plastered with Quartzscapes too and ours is fairly streaky as well. Our streaks aren't white though. But there are places that are darker and others that are lighter, and in some places you can see the trowel lines if you know where to look. Overall it looks good but it's not the greatest plaster job I've ever seen.
    15k gal freeform sport pool with rock waterfall. Replastered 5/2016 with Tahoe Blue Quartzscapes
    Taylor FAS-DPD K-2006 test kit
    Jacuzzi 2002 J 310
