Thread: Aqua Logic AQL-P-4
    Aug 2016
    Chandler
    3
    Aqua Logic AQL-P-4
    I have an Aqua Logic AQL-P-4 system and I am getting a "Very Low Salt Error"
    Cell is clean and has been tested in the store - it works fine. Salt level in the pools tests ok too.
    Does anyone know if this problem could be related to K1 relay?
    Any ideas welcomed. Thanks in advance.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Aqua Logic AQL-P-4
    welcome to TFP
    "Salt level in the pools tests ok too." from your statement it sounds like you are using test "guess" strips.. You really need the drop test kit as it will give you a much better salt level
    Amazon.com : TAYLOR TECHNOLOGIES INC K-1766 DROP TEST CHLORIDE SALT WATER : Swimming Pool Liquid Test Kits : Patio, Lawn Garden
    Aug 2016
    Chandler
    3
    Quote Originally Posted by cowboycasey View Post
    welcome to TFP
    So after further investigation I got to the bottom of the problem. As I said, salt levels and cell tested ok so I looked into the electronic board and saw that connection to one of the relays was fried (see pictures). I had to repair the board and all works fine.
    . IMG_4862.JPGIMG_4861.JPG.
    Aug 2016
    Chandler
    3
    welcome to TFP
