Results 1 to 9 of 9
Thread: Skimmer Plugs
    Skimmer Plugs
    Any new products on the market for plugging skimmer? I have a autocover that I like to leave supported in snow load during winter. My observation is everyone I know who lowers water below skimmer ends up replacing cover in 5 years....I am hoping for double. I tried the simpooltech plug two years in a row, both times it failed over the winter, but my pool noodle and gizzmo saved me. I don't want to risk it again. Are there other options? I think the plug would work if had some type of traction pulling it into skimmer? Any new ideas?
    30000 IG vinyl pool, DE Filter, SWG, autocover
    Northern Indiana
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Skimmer Plugs
    I used the same exact skimmer plug and it also let water into the skimmer, I also had the gizzmo in and worked perfect... I have not seen anything else that would work..
    I lowered my water level but did not use a cover and let snow, ice and dirt fill the pool over the winter, I got away with it because of being an above ground..
    Re: Skimmer Plugs
    I would think there would be a real good market for someone who could figure out a skimmer plug that truly worked throughout the winter and allowed IG pools the ability to stay full throughout the winter.
    Northern Indiana
    mariane's Avatar
    May 2012
    Southeast Michigan
    305
    Re: Skimmer Plugs
    Quote Originally Posted by Monkeylove View Post
    Last year we hard plumbed the lines and put in a disconnect to the skimmer and the discharge, left them open so excess water could drain out if the levels got too high. Also covered over the skimmer with the winter cover along with the pool. I can't remember using a plug, and have not used the skimmer winter cover gasket and plate for years. Have not had a problem.
    Quote Originally Posted by cowboycasey View Post
    Interesting concept cowboycasey. how does that work: does the water freeze to a solid block of ice in the winter? do you leave the skimmer open so higher water levels will drain out and not damage the skimmer window? is it a lot of work cleaning out the dirt and debris in the spring? Just curious. ;o)
    16 x 28 Doughboy Mystic Garden AGP with 7' deep end (used expandable vinyl liner) ~11,800 gals. Deep end main drain. Thru-the-wall skimmer, one return at deep end. Media Master 150# sand filter. Doughboy PowerPak II pump, 1 hp. Pentair MinimaxCH 150m natural gas heater. Polaris 65 when it feels like working . TF-100 test kit. No longer 'pool stored' 6 years and counting. In sunny but fickle metro-Detroit.
    Jul 2013
    Fletcher, OK
    3,353
    Re: Skimmer Plugs
    Quote Originally Posted by mariane View Post
    It worked great, last winter it only had about 1/2 inch of ice, nothing bad and ended up working great I do not think I am going to use the skimmer plug except to blow all the water out of the skimmer and install the gizzmo..
    Here are some pics of the pipes I used for closing and then what it looked like when I opened.. The last shot was after a day of filtering
    mariane's Avatar
    May 2012
    Southeast Michigan
    305
    Re: Skimmer Plugs
    Our pool becomes a solid block of ice and we get a bunch of snow. The idea of using the "snow" water to fill the pool in the spring is very tempting. We do have a lot of trees and the leaves fill the cover in the fall. Still trying to figure out a way to work thru that one.
    Thanks for the reply cowboycasey. Pool looks great. ;o) Do you use a manual vacuum? or auto sweeper like a Polaris?
    Jul 2013
    Fletcher, OK
    3,353
    Re: Skimmer Plugs
    I use "the poolcleaner" it is a little expensive and it does not scrub the liner and those are the only things that is bad about it... it works great and will clean my pool within a couple hours, it cleans as long as the pump is on and we never take it out, been running for 2 years now
    mariane's Avatar
    May 2012
    Southeast Michigan
    305
    Re: Skimmer Plugs
    thanks! will check into it. ;o)
    wjr75's Avatar
    Jun 2013
    IL
    836
    Re: Skimmer Plugs
    We keep our auto cover open when we close and have a Loop-Loc winter cover. We drain the pool down about 2 ft when it is closed and it is full by mid spring from snow and rain. I couldn't see how using the auto cover in the winter would even work but hay is what I say
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
