Thread: Beginner's Question Re: SWG
    Mar 2016
    Medford, Oregon
    180
    I currently have the circulation pump running for 3 hours daily for general filtration & chlorine generation. The SWG is set at 20%. That seems to stabilize the level of FC quite well. Maybe about once a week the level of FC drops to about 3 (from my target of 4). It seems easy just to add some liquid chlorine. However, is there a reason why I should set the SWG run time above 20% instead?
    [BTW, I just wanted to say "thank you" to everyone for their quick & insightful responses to my various questions over the past several months. As a newbie to the pool/spa scene, your help has put me on the fast-track to understanding the basics of water chemistry].
    Thank you for your help.
    Kit
    14' X 11' rectangular in-ground spa; 2,360 gals; plaster/gunite; SWCG (Pentair IntelliChlor); Pentair Intelliflo varaible-speed pump; EasyTouch4 control system; cartridge filters; auto cover
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Beginner's Question Re: SWG
    Alright, glad TFP is working great for you. I would increase it one notch. A little more FC is always better than a little less fc. Gives you a bit of cushion just in case.
    When the time is right have a look here, a new badge would look good for you!
    CLICK HERE to Become a TroubleFreePool.com Supporter!!
    Mar 2016
    Medford, Oregon
    180
    Quote Originally Posted by pooldv View Post
    Sounds reasonable. Thank you.
    Kit
