Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: Sand filter putting sand in pool
    I've got a sand dollar filter that seems to be putting sand in the pool. It seems like everything I'm seeing says it's a spider gasket. Does anyone have any advice before I pull the valve apart to replace the gasket? Thanks.
    Azle Texas, 38,000 gal blue gunite Salt water pool with a spill over Spa & 30 foot waterfall.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Sand filter putting sand in pool
    There's not really any reason sand should be passing through the spider gasket unless it's happening on backwash, and even then it wouldn't be much. How much sand is coming back in?
    Enough is coming through that it spots up all over the bottom of the pool. For the past two years I thought it was mustard algae, I've spent hundreds of dollars on algae killer. Yesterday I took the winter cover off, nothing in the bottom of the pool, cranked up the pump and within 30 minutes I had the spots all over the bottom of the pool. I've come to the conclusion that it is sand being put in from the filter because I didn't have anything there until I cranked up the pump.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    To see if it's sand, you can either reach down to the bottom and collect a sample and see if it's sand or, if you don't have 4' long arms ( :P ) attach a nylon knee-high to one of the returns to catch stuff coming out and inspect the contents (turn the pump off and on a few times over a 10 minute period, more stuff comes out when the system first kicks on)
    Do a little experimenting to see what the stuff is and we'll help you from there
    Luv& Luk
    -Ted
    I'll let you know what I find. Thanks.
    How well is your backwashing working?
    Have you stirred your sand?
    Could be the spider gasket.
    Could be clogged sand.
    20,000 US Gallon Oval with diving well but no board :( Hayward s244t2 & Multiport SP71621
    1hp AO Smith WhisperFlo pump / basket Part 7-177450-03 / 3 returns, well drain connected to jacuzzi overflow
    baracuda version 3 run to the overflow; side hookup add in process.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    it could be a broken lateral...it does happen on sand filters...if you can get a sample you'll know it's sand if it is gritty...sand in filters is pretty coarse vs. fine dust that usually settles to the bottom
    I just put new sand in the filter. None of the laterals were broken. I haven't had a chance to look and see what it is yet.
    Mar 2007
    4,160
    Did you backwash and rinse the filter after adding the new sand? If not, that could be the problem and it's done doing that now
    Luv& Luk
    -Ted
    Bob_Funk's Avatar
    May 2009
    Seattle-It really rains all the time
    113
    I had the same problem, new sand, good laterals, replaced the spider gasket-still sand in the pool.
    I took all the sand out AGAIN & dis-assembled the the whole lateral arm & there was a huge crack on the bottom of the piece that the laterals screw into.
    I would never have seen it if I had not taken the whole thing apart.
    The filter is old & 1st pool co. said can't get the part buy a new filter
    2nd pool co. couldn't find the part either but had a piece that my laterals would screw into & gave me 2 90 degree elbows & I was back in business for $17
    I went with option 2
    Bob
    I consider myself very lucky I found this site before the pool store found me-pool owner since Nov 2008- Stunningly clear 17,000 gal fiberglass pool, thanks to this site, installed in 1982-24" 3.1sq. ft sta-rite sand filter, 1 hp - 2 speed wisperflo pump-WFDS-4
    I put on some goggles and went to the bottom and felt it, it's gritty like sand. I guess I'll start with the spider gasket.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Quote Originally Posted by jde2
    From what I've seen people sometimes confuse dead algae for sand, usually if a cracked lateral is to blame and sand starts shooting out the return line it doesn't end up very far into the pool. The sand is so heavy is makes it only a foot or so and piles up on the floor. To make sure it is sand brush it, if it moves it is sand; if it fluffs up and disappears it's not sand.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    It does puff up and disappear. It feels gritty like sand. If it's dead algae, why can't I get rid of it? I've changed the sand a couple of times. I've put in every kind of algae killer there is, the spots keep coming back year after year.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    could you post a clear picture if possible?
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    I can try and take a picture but you probably won't be able to see it clearly. Basically, it's brown spots all over the bottom of the pool. I can brush the bottom of the pool and by the next day the're back, the longer I let it go without brushing the more spots I get. I rubbed it between my fingers and it feels like very fine sand or dirt. I'm at a loss. I've changed the sand 3 times and put hundreds of dollars worth of algae killer in it in past years. It didn't appear this year until after I took off the winter cover and turned on the pump. Before I turned on the pump, there was nothing, that's what made me think it was sand.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    12,093
    Sand, dirt, dust...dead algae, any of the above. Performing an overnight FC test can confirm if the substance is organics - or just pollen/dust/sand.
    I have it too, and I know it's not any form of algae, because my FC holds. And I have a cartridge filter....
    Sand filters can be tricky that way - did you try the kneehigh over the return to see what's getting thru the filter, if the filter is the issue?
    (sounds like a slight case of sparklypoolitis to me.... )
    X-PertPool's Avatar
    Exeter, PA
    1,385
    I re-read your description of your problem it actually sounds like mustard or yellow algae. I recently used Yellow Treat from united chemical and it works very well. If the brown grittiness is coming back in the same spot day after day I would think it's definitely mustard/yellow algae.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Quote Originally Posted by frustratedpoolmom
    My mother-in-laws pool had deposits of brown and her chlorine was holding just fine so I thought it wasn't algae either but the yellow treat I tried actually improved the pool, the brown went away and the deposits became fewer and lighter in color from a dark brown to a light tan or grey.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    Thanks. I'll gve it a try and let you know how it works.
  20. Back To Top    #20
    I put in the Yellow Treat and it didn't change anything.
