Thread: Replacing inground pool lights with LED lights
    Jun 2016
    Montreal
    9
    Hi,
    I have an inground pool (with vinyl liner) from the mid 80's. The previous owner had the inground lights installed when he built the pool, but when he changed the liner, he did not make the cutouts for the lights as he was fed up with leaks at the lighting area (or so he said...).
    I asked a pool specialist if he could cut my existing liner to get the existing lights working and he suggested against it given the liners age and risk of other damage. He suggested doing it the next time I change the liner...
    Given I have all my wiring passed and the advances with LED, I was curious if there were any options to convert to some sort of LED lighting that does not require cutting the liner. What products exist that can perform in a similar manner as the existing lights? I don't need anything fancy...just some basic lighting for the pool at night.
    Thanks!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Replacing inground pool lights with LED lights
    all the LED lights I have seen require the same connections as regular lights and I also would recommend installing when you change the liner.. these are really nice looking LED's and what I am leaning toward installing when I build an inground pool
    SAVI Pool and Spa
    Oct 2015
    Austin, TX
    83
    Toss a few battery operated floating lights in the pool?
    Pool: 16,000 gallons, 16x31, 500SqFt gunite pool, White Pebbletec interior, built by Cody Pools. Pentair Intelliflo VS-3050 pump, Pentair Clean & Clear 420 Cartridge Filter, In-line chlor with Ultra UV, PV3 Infloor cleaning, Pentair Easytouch-P4 control. TF-100
    Spa: 525 Gallons, Coast fiberglass spa of unknown vintage and suspect previous care with a 2-speed main pump and a blower motor, both 4HP. 3-step bromine sanitized.
    Apr 2013
    Sacramento, CA
    2,769
    In some cases depending on your pool configuration you can turn a return into a light by using the nicheless lights as suggested by Casey above. But they require losing a return.
