Results 1 to 8 of 8
Thread: SLAM and TA
    Jul 2014
    Norman, Oklahoma
    22
    SLAM and TA
    Thanks everyone for your help getting me through a SLAM process, it seems that everything is clearing up nicely.
    I do have one questions. Before I started my SLAM, my PH was 7.4 and my TA was 100. I know that when FC is really high that PH measurements are not accurate.
    Is this the same for TA? Because I tested my TA today while the FC was at 15 and TA registered 180. (PH measured 7.8-7.9)
    The only thing I have added to my pool in the last week was 8.25% chlorine bleach.
    18k gal IG Vinyl, 1hp Challenger Pump, Hayward Sand Filter, TF100
    Jan 2012
    'burbs of Augusta, Georgia
    7,348
    Re: SLAM and TA
    No, its just the pH test that isn't accurate.
    Jul 2014
    Norman, Oklahoma
    22
    Re: SLAM and TA
    What would cause the TA to almost double when I have done nothing else except add bleach for a week?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: SLAM and TA
    Two options. Somebody snuck in your yard and added some baking soda or testing error. Did you wipe the tip of the bottle on a damp cloth while testing? Not doing that can result in a falsely high result.
    That is included in the instructions on the TF-100 which uses Taylor reagents but sometimes not in the K-2006
    More detailed instructions here, Pool School - Extended Test Kit Directions
    Jul 2014
    Norman, Oklahoma
    22
    Re: SLAM and TA
    I did not wipe the tip of the bottle. I read that in the instructions but didn't really understand why I would need to do that. I will retest tomorrow
    Previously I was using the K-2006 test outside next to the pool when I got the TA of 100 and the TF-100 inside on my kitchen counter when i got the 180 result.
    DFW, TX
    24,497
    Re: SLAM and TA
    The first few tests it can build up a static charge and make the drop smaller.
    Jul 2014
    Norman, Oklahoma
    22
    Re: SLAM and TA
    That seems to be what the problem was. Thanks!
    I tested again today wiping between drops and the TA came out to be 100 again.
    DFW, TX
    24,497
    Re: SLAM and TA
    Alright! Good job fixing your pool!
