Results 1 to 8 of 8
Thread: Step 1: Test, Step 2: Consult the Experts
    Mermanaid's Avatar
    May 2016
    Plano, Tx
    68
    Hi, all ... the pool builder has turned over the pool chemistry to us (I thought they were going to manage it a bit longer but ... that's a different story!). Feeling a bit overwhelmed but I know this whole testing routine will become second nature in time. So, posting my FIRST set of tests with the TF-100 kit and would love your advice. I've repeated the tests twice just to make sure I got them right and feel pretty confident with the second round (just a little different than my first result).
    PH: 8.2
    FC: .5 (took one drop)
    CC: .5 (took one drop)
    CH: 75 (7 drops)
    TA: 50 (5 drops)
    CYA: I haven't been able to do this with my test kit yet but using the Aquacheck strips from the PB it's registering 30 - 50.
    So, if I understand my next steps:
    1. Lower PH with muriatic acid. Goal = 7.5 Amount of MA to add depends on the type I find at the pool store (thanks Pool Math for telling me there are so many options!).
    2. Get bleach in this thing STAT. Add 91 oz 8.25% bleach.
    3. Increase CYA. I am in Texas so I think I should target 80? I'm not exactly sure but will do the CYA test in the morning to compare it to the Aquacheck strip.
    So wise ones ... am I on my way or am I just delusional (and I am okay if you tell me that).
    IG 28x15.6 gunite pool/spa (3.5/5/4), 13.6k gal, 4 Jandy 20W LED Lights, Zodiac VS Pump, 460sqft Cartridge Filter, Jandy Gas Heater, AquaLink, Polaris 3900, Zodiac 1.5HP Metal Blower, Pentair Inline 320 Chlorinator, Venetian Travertine Paver Deck, Leuder's stone coping, PB custom crystal pebble plaster (blue granite)
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    Re: Step 1: Test, Step 2: Consult the Experts
    Good job starting this pool up right!
    Why can't you test the CYA with the TF-100??
    Get that FC up, and as soon as that is done get your CYA in there. If you DO NOT have a SWG aim for no more than 50 if you're in the sun more than not.
    But if you have a SWG (which I can't tell from your siggy line) aim for 80. Sneak up on that goal rather than plopping it in all at once. You do not want to over shoot this one.
    Your CH needs to come up. Use PoolMath to bring it up to about 300 to start than you can tweak more as you see how its going. If you don't do this the calcium in the plaster will be leeched out and weaken your plaster.
    Be aware that new gunite will cure causing increase in pH which will require frequent doses of MA.
    Learn how to use PoolMath to monitor your C.S.I.- goal is between -3 to +3
    Mermanaid's Avatar
    May 2016
    Plano, Tx
    68
    Thanks, YippeeSkippy! I thought it was best to test CYA first thing in the AM? I have all the stuff just figured I would wait until in the morning.
    Just dosed pool to get ph down to 7.5 and FC to 5 (kind of a guess because I don't know exact CYA).
    Boy that MA is some scary stuff. Now I know why the guy who did our acid wash was hacking up a lung.
    I'll work on CH tomorrow after another visit to the store. Should I also worry about TA or focus on CH for now?
    ETA: no SWG for us.
    Mermanaid's Avatar
    May 2016
    Plano, Tx
    68
    Just retested.
    PH: 7.2 (overshot a little. Hmm)
    FC: 5 (yeah baby!)
    CC: .5
    Mermanaid's Avatar
    May 2016
    Plano, Tx
    68
    Another random question. We have in inline chlorinator and was wondering if we could put stabilizer in a sock in it or baking soda, etc.
    Mar 2015
    South Texas
    411
    Quote Originally Posted by Mermanaid View Post
    No, don't do that. You can add stabilizer in a sock hanging in front of a return. Squeeze the sock frequently and it will dissolve quicker.
    15,000 gallon free form Viking fiberglass pool. Hayward Star-Clear Plus C12002 cartridge filter. Hayward Swim Pure Plus T-15 SWG. Testing with TF-100 Kit. 2 speed 1.5HP Supreme pump. Dolphin Nautilus robotic cleaner
    Mermanaid's Avatar
    May 2016
    Plano, Tx
    68
    Quote Originally Posted by nlindelldc View Post
    Thanks for the quick answer. Guess it will only be used while we are on vacation! Is there a reason why we shouldn't use it to disperse (just asking out of curiosity)?
    Aug 2014
    Northern IL
    4,615
    It takes a while to dissolve and if you disperse it, the granules would settle to the bottom and bleach your pool surface.
