Results 1 to 11 of 11
Thread: FC is Climbing
    Rsmith's Avatar
    Apr 2016
    Central Md.
    107
    FC is Climbing
    2 weeks ago when I did my weekly test my FC had climbed from 8 (where it has been all summer) to 11.5. I reduced my percentage on the SWG from 68 to 55. Last Sunday it was 11.5. Today it was 14.5. I reduced the SWG to 35% this morning. It is a new pool (filled early May). What could be causing this spike?
    Central Md. 37 X 21 24K IG Custom Gunite with Anvil Quartz finish. Raised Spa.
    Sta-Rite Natural Gas Heater. Intellichlor IC-40 SWG, Sta-Rite 450 sq ft. Cartridge Filter.
    Pentair 1.5 Hp Variable Speed Pump. TF100. Dolphin Z-5. First swim 5/26/16
    JoyfulNoise's Avatar
    May 2015
    13,173
    Re: FC is Climbing
    Has your water temperature dropped?
    Matt
    Rsmith's Avatar
    Apr 2016
    Central Md.
    107
    Re: FC is Climbing
    it fluctuates between 83 and 90 depending on weather. It is in direct sun from 9am until 5/6 pm.
    Rsmith's Avatar
    Apr 2016
    Central Md.
    107
    Re: FC is Climbing
    It has been about 10 degrees cooler this week. Highs in the mid to upper 80's. Last few weeks were brutally hot.
    Rsmith's Avatar
    Apr 2016
    Central Md.
    107
    Re: FC is Climbing
    Water temp was 81 this morning. I could smell the chlorine. #'s were off the chart. I set the SWG to enable off. Not sure whats going on. I'm at work now but will test again tonight. Ill probably unplug it for a few days to get numbers back to normal. Any idea why this would happen?
    May 2015
    13,173
    Re: FC is Climbing
    Possibly a defective cell? Front lights on the cell confirm that your changes in the EasyTouch automation panel are registering?
    Matt
    Rsmith's Avatar
    Apr 2016
    Central Md.
    107
    Re: FC is Climbing
    Not sure. I changed the running hours from 6-9 to 6-5 yesterday morning but when I came home at 7 the pump was still running. I turned it off manually. This morning it was running again when I looked out the window at 7 am. Does it take a day for changes to take effect? When I dropped the SWG down this morning to 10% it still showed the 40% light on top of unit. That's when I decided to turn the enable to off. The lights were still on after I did that. Just called home, still at 40%.
    May 2015
    13,173
    Re: FC is Climbing
    Something is not right with automation panel. You may need to reset it. Schedule and SWG output changes should be instantaneous (or at least take effect at the start of the next cycle).
    Matt
    Rsmith's Avatar
    Apr 2016
    Central Md.
    107
    Re: FC is Climbing
    I think that is what's happening. I just called home again and the pump was off. I had changed it yesterday to turn off at 5 instead of 7. I think the SWG will reduce its output tomorrow. Ill leave it plugged in tonight and then will look at it tomorrow. Thanks for the help. Ill update with numbers tomorrow night. Hopefully the rest of my chemistry is holding true.
    Rsmith's Avatar
    Apr 2016
    Central Md.
    107
    Re: FC is Climbing
    PH 7.2
    FC 12
    CC <.5
    CH 500
    TA 70
    CYA 60
    Salt is showing 4200
    CSI -.5 Temp is 81
    Ill check numbers again in morning along with SWG settings. Thanks again for any advice.
    May 2015
    13,173
    Re: FC is Climbing
    Your numbers are fine. In fact, with a. FC/CYA ratio of 20% you're in "mini SLAM" mode
    All should be fine. Just get your automation sorted out. Sometimes the logic board will go bofo if there's a power surge or dip and you need to reset the unit. There's a way to reset the EasyTouch without wiping out the programming. I've not had to do it but you should look it up.
    Matt
