Thread: Pump choose
    Nov 2015
    CA
    12
    Pump choose
    Hey guys. I'm planing on getting a new pump. There's my current pump.
    A.O.Mith
    CAT B748
    SERIAL CB01-23
    HP 2.0
    SF 1.3
    HZ 60
    RPM 3450
    VOLTS 230
    AMPS SF 11.5
    I just installed a Hayward S310T2 sand filter and drained the pool due to the high CYA level(around 300ppm)
    My pool is around 20000 to 25000 gallons. Inground pool and spa, one skimmer, one vacuum, two main drain and a water fall.
    I was wondering if I can choose a 1.5HP variable speed pump because SCE has 200 dollars rebate right now. I live in South California. Thanks for taking your time to read this. I appreciate your help.
    Apr 2015
    tucson, arizona
    1,128
    Re: Pump choose
    Are you looking to replace the whole pump or just a new motor? What model pump do you have, if you go with 1.5hp you would be downsizing a little.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,512
    Re: Pump choose
    Does that pump also operate your spa? Or only your filter? Filter only then yes the 1-1/2 hp VS is fine. If it is running your spa too then you might want to go with a 3hp VS pump.
    Nov 2015
    CA
    12
    Re: Pump choose
    Quote Originally Posted by kadavis View Post
    I'd like to just switch the motor. But the pump is a little bit old, I'm afraid I may not be able to find a replacement part.
    Quote Originally Posted by pooldv View Post
    The pump operates both the pool and the spa.
