Thread: Hayward wide mouth skimmer
    Jul 2012
    Richmond, Va.
    43
    Was going to replace my AG 18 ft lomart skimmer with a standard Hayward skimmer.
    Does the new wide mouth model really make that much difference?
    My skimmer is located under a trap door in the deck and may have to make some modifications if I went to the wide mouth.
    To change to either skimmer planning on using some 26 gauge stainless sheet metal.
    Thanks
    6014 gallons aprx
    cartridge type filter
    summer escapes pool above ground metal frame
    SFS1000 SkimmerPlus filter pump with GFCI=1,500 GPH
    install date: 6-1-12
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Hayward wide mouth skimmer
    I went with the wide mouth, I am not sure if it made a huge difference but it's suppose to allow a longer time to let debris get sucks into the skimmer
    domct203's Avatar
    Jun 2015
    CT
    3,578
    I have a standard Hayward skimmer & use a "Skim it" which I love.
    Skim It Skimmer Arm ─ Pool Cleaning Accessories ─ In the Swim
    HTH,
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
