Results 1 to 18 of 18
Thread: Heavy Duty Pool Ladder needed...I'm WAY over limit on the included one!!!
    Jun 2016
    Panama City
    100
    It has already started to bend and is touching the top of my Summer Waves Polygroup pool. Im on a huge budget crunch now that the insurance has deemed that we had to have a fence. The fence was completed last weekend and the kids have no problem with the cheap ladder. Im thinking of reusing pallets to make a set of pool steps for outside of it. and then using a regular 6' step ladder cut down and adapted to the top step of wood steps and then saving up for some type of normal ladder next year. My budget is under 200, like closer to 100. I have a 6' step ladder that i can cannibalize to use inside pool with something to protect the pool bottom. Am I way out in left field or could I do that? maybe make a set of wood steps for inside the pool? I plan on taking down pool in October. Any comments appreciated....
    6500 gallon SummerWaves AGP. Taylor k-2006, Jacuzzi sand filter and two speed pump. City water. Third year in use!
    Jun 2016
    Panama City
    100
    Re: Heavy Duty Pool Ladder needed...I'm WAY over limit on the included one!!!
    cant get pic to load
    Casey's Avatar
    SW PA
    10,461
    I would never use a metal step L adder or wooden steps in a pool. Have you checked Craigslist in your area?
    Jun 2016
    Panama City
    100
    I was thinking the front half of a fiberglass 6' ladder and chop off the bottom step and replace the feet with a carpet wrapped 2x4 to protect the pool liner. attached to a set of steps that I build from new 2x12's and reclaimed pallet wood for the treads.
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    360
    Pallet lumber is not treated; it is the cheapest wood available. Thus it will rot and attract termites. If you do use wood, make sure that a: it's pressure treated and b: any that contacts the ground is rated for "Ground Contact". Usually only 4X4 and 6X6 are gc in home stores. Contractor stores will frequently have other dimensions in gc, especially 2X12 used for stair stringers. As far as your treads, decking lumber will work - but consider how many tender bare feet will be climbing (running?) up and down those steps.
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    Jun 2016
    Panama City
    100
    I was going to carpet the steps. The pallet wood only needs to last the rest of this season....next yr I would get wedding steps or a frame ladder. I was going to use GC lumber for stringers and braces.
    LittleTagAlong's Avatar
    Jun 2016
    Amarillo TX
    119
    I made my steps to pool with pallets (ck for treated, found mine at lawn mower place), cannibalized pool ladder, treated lumber, simpson ties and deck blocks from Home Depot. It cost a little more than I wanted but I needed a way to feel safe getting in and out. I don't care if I fall in but sure don't want to hit ground. This bumble doesn't bounce. [IMG][/IMG][IMG][/IMG] Btw, the steps are padded with foam pads for garage/gym floors [IMG][/IMG][IMG][/IMG] Hope this helps or at least gives you some ideas.
    AG, Intex 18' x48" Easy Set pool( =/- 5455 gal)
    Intex SF80110 sand filter & SWG ECO 7110, Hayward AquaCritter
    Well water, location is north Texas, usually up from late May to Oct.
    Taylor TF-100 test kit, TDS Digital Salinity meter and Taylor salt kit
    Jun 2016
    Panama City
    100
    Thanks! It sure does! That is what I'm thinking. I just might use wood inside the pool too!
    Jun 2016
    Panama City
    100
    Here is my setup see below
    Jun 2016
    Panama City
    100
    Attachment 53135finally! You can see the bending ladder!
    Jun 2016
    Amarillo TX
    119
    Quote Originally Posted by JEC11718 View Post
    I don't think I would use wood inside the pool. Imo, that might cause algae problems. Have you seen docks in lakes?
    Jun 2016
    Amarillo TX
    119
    Quote Originally Posted by LittleTagAlong View Post
    Sent from my 6045O using Tapatalk
    Had a thought...maybe use trex decking in water?
    Jul 2014
    Queensbury, NY
    14
    There are posts on pinterest where people have made steps for inside of their pool out of plumping pvc and trex decking. Try looking there for some ideas. I wouldn't use wood or a fiberglass ladder in the pool.
    Intex 16'x48" Ultra frame AG, Saltwater Generator
    Jun 2016
    Panama City
    100
    Thanks everybody! We had almost 15" of rain in the last week. I drained my pool four times...3", 3", 4", 5"! I didn't feel like constructing anything last week....but this week I have three days off. I am planning to do pressure treated on outside of pool and will use trex or similar inside... on the plus side...my water is still crystal clear by using tfp method! I do have to add more cya this week.
    Jun 2016
    Amarillo TX
    119
    Great! Would love to see pics of finished steps.
    Jun 2016
    Panama City
    100
    Here are the steps with your idea of reusing half a ladder. It needs a railing but its being put on this weekend. I'm thinking of using black iron pipe cleaned and clear coated for the railing. IMG_20160818_155116855.jpgI cut those stringers myself! And there are two uprights on each side, one is under the stringer. The other is the one you see on the face of the stringer.
    Jun 2016
    Amarillo TX
    119
    That looks nice.
    Jun 2016
    Panama City
    100
    Thanks!! It's a work in progress but it's so nice to have a pool and it's really easy to get out of now!
