Thread: Pool Slide Cleanup?
    Pool Slide Cleanup?
    I recently bought an older SR Smith slide from someone who was replacing it. The slide has what looks to be aluminum supports and ladder. It has 3 support posts. The slide ladders has some paint and other buildup on them and overall alot of oxidation. I was wondering if someone could recommend what to use to clean this ladder and support posts to look good again. I'm also wondering where I might find the hardware I need to attach this to my concrete. The slide has no feet or anchors just the posts. I will be attaching to concrete. Thanks for any help
    Patiently waiting for an in-ground oasis.
    DaveNJ's Avatar
    Toms River, NJ
    Re: Pool Slide Cleanup?
    Take a look at the attached for cleaning. I have used semi chrome polish for aluminum on my motor cycle. ... leaner.htm
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
