Results 1 to 10 of 10
Thread: salt system not working
    Aug 2016
    walnut creek
    3
    I have a intex krystal clear mod. cs8110 salt generator that has been working great several years now. However, recently the system does not come out of sleep mode once the pump comes on. I tried reprograming it to no avail. I have to turn it off then on to get it to go into the working mode. What could be the problem? Thanks
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: salt system not working
    Welcome to TFP
    Intex is a great cheap product that may or may not last more than a couple years.. if it is having issues most just replace it with a new one..
    what is your CYA level at, if at 70 to 80 it will help your SWG
    Aug 2016
    walnut creek
    3
    what would you consider as a step up in quality salt generator?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Add your pool info to your signature and your state to your location so that we can better help you. More here here on what to put in your sig and how to do it, Pool School - Read This BEFORE You Post
    Aug 2016
    walnut creek
    3
    3400 gal above ground, vinyl medal framed pool (intex 15x35)salt gen as mentioned, intex mod 633T cart. filter pump. chem checked at pool store twice amonth and use strips daily.
    Its the first year using this pool.
    3400 gal above ground vinyl frame pool (15x36)
    salt generator as mentioned. intex krystal clear mod. 633T cart. filter pump. water restrictions:on in california. chem tested once amonth at pool store.
    DFW, TX
    24,509
    The Intex SWG is a good choice for your pool.
    Jul 2013
    Fletcher, OK
    3,353
    I agree, the intex is perfect for your size pool and not expensive
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,550
    My local Academy Sports had them today for $89. Normally $179. I almost bought one just to have a spare. A new cell costs almost that much.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    DFW, TX
    24,509
    Yeah, the late summer intex sales at Academy and Target are usually pretty good.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,550
    Wouldn't you know it? I got home last night and my FC was low. Checked my SWG and the low salt light was on. My salt level is high, if anything. So I cleaned the cell with MA and it came back on, but was off again this morning.
    I went back to Academy, and all of the SWG's they had Saturday for $89 were gone. Grrrrr!
    I think they were the smaller, 5 g/hr units anyway. So I just ordered a new 12 g/hr one on Amazon for $148. Should be here Friday.
    Meanwhile, gonna have to stop by Wal Mart on the way home for some bleach.
    Pentair IC40 SWG
