Results 1 to 8 of 8
Thread: Chlorine Loss Question
    Jun 2016
    Tyler, TX
    14
    Question Chlorine Loss Question
    Good morning all. Have a quick question for the forum. I have a CYA level of 140 and I have been having to keep my FC levels relatively high. Ranging between 12-18 ppm. Initially I was keeping the chlorine around 18 ppm and in the last month started keeping it at 12 ppm. Each day I was having a loss of about 4-5 ppm. I havent had time to do a SLAM yet, due to work, but each day I just add enough chlorine to get me back up to 12 ppm. I have noticed over the last two days that I have started only losing about 2 ppm. My question is, would this indicate that whatever is eating my cholorine is going away? What would be your sugggestion going forward?
    FC: average 12 ppm
    CC: .5
    TA: 100
    PH: 7.8
    CYA: 140 (will drain after the season is over)
    23k IG gunite pool, Pentair 1HP 2-speed Superflo, Pentair Quad 80 DE filter, Polaris Cleaner, Taylor Testing Kit
    VinDeeLoo's Avatar
    Jun 2016
    Tonkawa/Oklahoma
    204
    Re: Chlorine Loss Question
    Has it not been as hot or sunny the last few days? Also, has the swimmer load been less the last few days?
    VinDeeLoo
    7600 gallons ~ AG ~ Summer Waves Cartridge C Filter ~ using pump that came with our Summer Waves 18 x 48 pool ~ Taylor K-2006 (SpeedStir & Sample Sizer) ~ no well water or water restrictions
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    The way to tell if you have something growing is to do an OCLT. Test the FC after the sun goes down and before the sun comes up. Pool School - Perform the Overnight FC Loss Test (OCLT)
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Jun 2016
    Tyler, TX
    14
    Swimmer load hasnt changed and its been about 101 everyday.
    I am aware of the OCLT test and will try that. I appreciate the info.
    My testing has been done about 5 PM each day. It just seemed weird that for the longest is has been religously dropping by 4-5 ppm each day and the last couple days, no change in swimmer load or temp, it has gone to 1-2 ppm per day. It just seemed odd.
    I will try the OCLT test this evening and in the morning and report back.
    30,431
    Just as an aside, you could probably get that loss to a permanent 2 ppm if you drained half your pool and replaced it with non-CYA water.
    I was going to jump on the heat issue but you already have that covered. I have no explanation for your reduced loss.
    Since you are losing only 1-2 ppm in the daylight, I doubt the OCLT will yield any clues.
    Gig 'em!
    Jun 2016
    Tyler, TX
    14
    OCLT test done and it started at 11 ppm and in the morning was 10.5 ppm. I guess whatever was eating my chlorine is gone. Now I maintain my FC rates at 12 ppm. Any other suggestions?
    Jun 2014
    15,221
    Only one other thing to do now ....
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    Great news!
    Karen
