Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: Anybody have their Intex AGP liner lose its color?
    Apr 2016
    College Station, TX
    79
    All of the color in mine has gone away below the water line. It's just white now. I've been pretty religious about keeping the FC level inside the FC/CYA chart. I did SLAM once for 4 days with one overshoot but the fading started well after. It happened over about a month, or maybe three weeks. This is the 3rd year for the liner and first year for TFP. It had a few bleached spots from where shock granular settled on the bottom from years past before switching to TFP.
    I'm not sure it's all bad. A solid white pool is kind of neat. But now I'm thinking of ways to dye the water. Using TFP, the water is so clear, I don't think I'll ever be able to keep that white bottom clean.
    Intex 16'x32'x54" 17Kgal AGP since 2014. Sand filter, Hayward skimmer, home built 10'x15' deck and stairs, solar heater. High TA tap water, moderate rainfall, weekly use. Treated with 10% bleach, MA and some dichlor initially. Soon to add borates.
    Taylor K2006C
    Future projects - automatic chlorine pump, online pool sensors, better heater, IGP (maybe)
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,556
    Re: Anybody have their Intex AGP liner lose its color?
    Yes, after 3 years mine is nearly white as well. Other than that and a couple of small rust stains on the support tees, there's really nothing wrong with it, and I leave it up year round.
    I don't really mind it, but I won't be too upset if I have to replace it next year either. I figure 3 good years out of one of these pools is a bargain
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Do you have a picture you can post?
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,556
    Here's a video of mine with my Intex robot running around. I think this was after dusk, so no direct sun. But notice that you can no longer see the squares on the bottom of the pool.
    Intex Auto Pool Cleaner, aka - YouTube
    Pentair IC40 SWG
    Sep 2015
    Rancho Cucamonga, CA
    53
    Only the bottom or the sides as well?
    Intex Ultra Frame AG Round 16'x48", 5050 gallons
    Intex 28651EG Sand Filter Pump (had SWG, still have salt in water)
    Intex Auto Pool Cleaner, Intex Wall Mount Skimmer, Intex LED Pool Sprayer
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,556
    Everywhere below the waterline.
    Pentair IC40 SWG
    RonsPlc's Avatar
    May 2015
    Gaylesville, AL
    459
    yup... THE main reason I put in an overlap liner this year! Installing replacement liner inside of Intex 18' metal frame - Page 10
    The difference in appearance is remarkable! Plus I can now fill my pool ALL the way up to the top rail. We love it.
    14600 gal Intex 24' Round 52" deep AG Pool (Heavily Modified)
    200lb sand filter w/2 speed 1.5/0.5hp pump
    Stenner 45MHP10 Liquid Chlorine (well... bleach) Injector. Borates added.
    K-2006 test kit w/Speedstir
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I really wish they would come up with a new pattern for the ultra frame liners. My is a bit lighter this year than last, I think. I left it up all winter uncovered.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,556
    Here's how faded mine is.
    Pentair IC40 SWG
    john.esher's Avatar
    Jul 2015
    Havertown, PA
    40
    Mine has started, though not nearly as bad as the ones posted above. But it's only our second year, and I took it down last winter. I won't be doing that this year, so I'm guessing it's going to gets worse. I'm always envious of the other liners I see here on the forum, and with a little more work, we'll have one in a few years.
    Intex 18' x 52" AG with Sand Filter Pump & SWG (Model ECO15110) about 7,600 gallons tested with a K-2006-SALT.
    Apr 2016
    College Station, TX
    79
    Mine was fine until about a month ago when it started bleaching out very fast. Everything below the water line but the bottom is almost completely white while the sides still have a little bit of color. This is the first year I have used bleach to treat the pool. So I have three theories.
    1. Bleach will cause a liner to bleach out
    2. The water is soooo clear now that the sunlight was able to bleach it out.
    3. While I was gone for two weeks, my wife over serviced the chlorine level.
    In any case, it doesn't bother me too much. I got in just after noon today and noticed a huge difference in temperature zones with the top foot very warm and getting progressively cooler deeper. The pump hadn't run since about 5 am so there was not mixing in the water. I wonder if that is because the white bottom doesn't absorb as much heat as the dark blue did or if I just never had gotten in after the water heat soaked with no circulation.
    It would concern me if I were to get a new liner. Anyone else have a theory on why this happens?
    Taylor K2006C
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Quote Originally Posted by welbo View Post
    If you all can provide us with the CYA level and what you keep your FC at, it might help diagnose any problems.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,556
    The faded liner makes the pool look more turquoise, which I kind of like.
    Pentair IC40 SWG
    Dec 2014
    Santa Ana, CA
    523
    I think your #2 is not applicable as the Sun shines on the liner above water line too but it didn't affect it that much. Must be #3 then
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
    Apr 2016
    College Station, TX
    79
    Quote Originally Posted by max2k View Post
    Yeah, I was happy to pin it on her but she's actually pretty good at testing. Then she calls me and I look up the quantity to add via pool math. My CYA has been at 50 and I've been running FC between 5 and 9. That may not be exact. I go by pool math. Whatever it says. I've been using Wal-Mart Pool Essentials 10%. I usually add about a half gallon a day.
    Taylor K2006C
    BobbyR's Avatar
    Jun 2013
    Toronto, Ont
    142
    Well, I hope that number 1 isn't the culprit. My previous liner was almost white when I replaced it in the Spring after only a year of using chlorine. It was already faded when I switched to TFPC so I really can't be sure but I'm watching very carefully for signs of fading in my new liner. If it starts to bleach out below the water line I don't know what I'll do because the water in my pool is absolutely pristine. Best it's ever been.
    Lagoon 40x22, Vinyl, 27,000 gal, 1HP WhisperFlo Pump, Pentair 60 gpm Sand filter, Hayward Brominator (used for chlorine pucks only when away), Rheem gas heater, Dolphin M4 Robot
    Waterfall on separate dedicated pump
    domct203's Avatar
    Jun 2015
    CT
    3,597
    4. Intex used the cheapest ink to meet their price point.
    My money is on #4, especially when TFPC is involved.
    It's amazing that even with everything we teach here about CYA to FC ratios & minimal chemicals, a lot of people will still blame the bleach.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Apr 2016
    College Station, TX
    79
    Quote Originally Posted by domct203 View Post
    Dom
    I figured someone on this board was going to be offended by my question. But if you follow the logic, the bleach is a natural conclusion. And your insinuation that TFP has exposed my liner to less chemicals is surely wrong. On the contrary, when I was treating with dichlor and tabs, my cya level had likely climbed very high. And I was not nearly as active in testing and treating the water. So the water back then likely had lower effective chlorine most of the time.
    I have no doubt Intex used low quality ink. It seems like three years may even be a natural life limit to these liners. It's hard to argue that bleach didn't play a role though. As I said above, my water has been "properly" chlorinated this year, where it was likely under chlorinated for a lot of the previous years. So it may be that a faded liner is a side effect of beautiful, sanitary pool water. I'm OK with that and it looks like a lot of other folks are too. That was the purpose of the post... learn if it was just me and if not how other folks handled it.
    Taylor K2006C
    domct203's Avatar
    Jun 2015
    CT
    3,597
    I'm not offended at all, nor should you be by my post.
    There are thousands of vinyl liner pools on this forum. If 'proper sanitation levels' were bleaching out 'quality inked' liners I would be suspicious, but that does not seem to be the case at all.
    I love my Intex pool, second season with TFPC and I don't yet notice fading. I'm sure the chlorine bleached the liner as well, but is most likely not because of the TFP recommended FC levels, but because of the lower quality, less chlorine resistant inks used.
    If you wrote on the inside of your pool with a Sharpie (or other non-chlorine resistant marker), and it faded out, would you blame the chlorine, or the Sharpie?
    Dom
    Dom - TFP Guide
  20. Back To Top    #20
    30,432
    What is it in the bleach that causes this? OMG, it's chlorine!! That's hardly a revelation.
    Well, if it's chlorine, why doesn't everyone's liner bleach out? I believe it is because there are certain guidelines that we have learned to follow that protect us from that. They are widely published and wildly successful.
    Can a liner be so cheaply printed that even normal guidelines don't work? Yes, I believe that, also.
    Intex notoriously makes the very cheapest pools and pool parts......that they might print a liner with the cheapest materials makes sense, too.
    Why did your liner fade?
    1. Overdose of chlorine outside safe guidelines? Perhaps
    2. Cheap printing with inferior inks? Perhaps
    3. Maybe a combination of both? Very likely
