Thread: pool calculator, which % to use
    May 2008
    rock springs, wi
    I am using a liquid chlorine product called "Ultra Shock" pool shock. The label states available chlorine 15%, sodium hypochlorite 12.5%, the rest is inert ingredients. Which % do I use in the pool calculator? Thanks in advance.
    27' AGP with 6' deep end (AquaLeader); 3/4 hp, 2 speed pump (Pentair); 22" sand filter (Pentair Sand Dollar); 2 4x20 Solar Bear panels with Goldline control valve
    Feb 2008
    Flower Mound, TX
    Re: pool calculator, which % to use
    Go with the 12.5%. That's the amount of sodium hypochlorite by weight and that is what you are interested in.
    10K gallon IG gunite with waterfall; Pentair CC320P filter; WhisperFlo 2 HP pump
    TF Test Kits - Pool Math - Pool School
    "It depends."- JohnT
    Mar 2007
    San Rafael, CA USA
    The label must be wrong in some way because the 12.5% with 15% doesn't work. The relationship of different percentages is as follows:
    % Available Chlorine by Weight < Weight % Sodium Hypochlorite < % Available Chlorine by Volume (aka Trade %)
    For typical 6% bleach and 12.5% chlorinating liquid, this is as follows because bleach is typically listed by the weight % of sodium hypochlorite while chlorinating liquid is normally spec'd by Trade % which is % Available Chlorine by Volume:
    5.71% Available Chlorine by Weight < 6% Weight Sodium Hypochlorite < 6.17% Available Chlorine by Volume (Trade %)
    10.78% Available Chlorine by Weight < 11.31% Weight Sodium Hypochlorite < 12.5% Available Chlorine by Volume (Trade %)
    It's hard to know what they really mean by their label, but as was suggested you should just use 12.5% in The Pool Calculator and see how things go.
