Thread: Muriatic Acid Question
    Jun 2014
    Merrimack NH
    5
    Hi everyone,
    Stupid question here but I am looking for other's opinions.
    I do not like to add muriatic acid and would prefer to get it in the pool quicker than a slow pour in front of a jet. My question is if I were to add it more quickly (say similar to adding bleach) and then running my Polaris pool vacuum to make sure it is mixed correctly would this be ok? I am aware that if I add the acid too quickly it can settle at the bottom of the pool, but I am ok with this if the Polaris (or any other pool vacuum) can make sure that it is mixed properly.
    I understand that this may not be the optimal way to add muriatic acid but I am trying to determine if there are any negative consequences if I were to add the acid more quickly.
    Thank you!
    -Matt
    26,000 gallon gunite pool
    FC 4
    CC 0
    PH 7.8
    Alkalinity 70
    Calcium Hardness 300
    CYH 40
    Borates 50
    Temp 80
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Re: Muriatic Acid Question
    I agree, MA is some nasty stuff....
    It could settle on the bottom if you pour too quickly.. Recommend you brush the area directly around where you poured just after you are done... Itll help get the rest dispersed if there is any.. If you run your robot, it could potentially degrade it...
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
    VinDeeLoo's Avatar
    Jun 2016
    Tonkawa/Oklahoma
    204
    I would not add it fast.
    VinDeeLoo
    7600 gallons ~ AG ~ Summer Waves Cartridge C Filter ~ using pump that came with our Summer Waves 18 x 48 pool ~ Taylor K-2006 (SpeedStir & Sample Sizer) ~ no well water or water restrictions
