Thread: More chlorine
    Aug 2016
    Belgium
    2
    More chlorine
    Hi,
    I got a quick question.
    I live in Belgium and i notice that the chlorine levels in Usa are much higher then where i live.
    Where I live the recommended level is between 1.5 and 2 ppm.
    Anyone got an explanation for this?
    Greets,
    Tom
    Jun 2014
    15,093
    Re: More chlorine
    Hi Tom and welcome to TFP! The difference you are seeing is primarily related to TFP using more relevant information to ensure (Free Chlorine) FC and CYA (stabilizer) are balanced properly and safely to sanitize water. Many pool industry levels still follow antiquated guidance and don't really account for the increased CYA levels in pools. As you can see from the Chlorine/CYA Chart (link below), a higher CYA level requires a higher FC level as the two items work together to sanitize and protect the swimmers from the effects of chlorine. Depending on the pool's location around the world, intense heat and sun UV will demand a higher CYA to protect the available FC. As long as the two (FC/CYA) are balanced together properly as noted on that chart, swimmer safety and sanitization are maintained. Hope that helps.
    WalterWhite's Avatar
    Jun 2016
    Philippines
    15
    Re: More chlorine
    Maybe in Belgium, because there are lower temperatures and less sunlight than much of the USA there is less utililisation of Cyanuric acid. Therefore, pools would be managed with lower chlorine concentrations.
    Do you use Cyuranic acid?
    Nueva Viscaya, Philippines, IG, 36cum reinforced concrete, ceramic tiles. Completed June 2016. Hayward kit: DE6020 filter with 6 way Vari-flow valve, Max Flow XL SP2707Z1M single speed pump, Chlorine Feeder CL200. Perimeter overflow skimmer to sump. Waterfall feature. In pool LED lighting. Test kit BlueDevil pH, TCl], FCl, Alk, TDS meter, pH meter. Filled from my own well.
