Thread: Pump Choice Advice Please
    Jul 2012
    France
    1
    Hi,
    I have a pool in France, 80m3 (20000 USG), SWG, glass media filter, 1HP fixed speed pump that draws 4.5A @ 230V & runs for 12 hrs a day during the summer, costing about $1.50 per day, $270 per season on cheap rate electricity. Pool cleaner is electric.
    Am considering changing to a more efficient pump such as Pentair Intelliflow but not sure that I need variable speed since I don't vacuum clean. However, I do need to backwash every few weeks.
    Is the Intelliflow a cost effective choice for me or would you recommend something else?
    Thanks for any advice,
    Roger
    Mar 2015
    South Texas
    411
    Re: Pump Choice Advice Please
    From what I have read on here a 2 speed pump is just as good as a variable speed and is a lot cheaper. I have also read good things about Pentair pumps. I'm considering switching myself.
    15,000 gallon free form Viking fiberglass pool. Hayward Star-Clear Plus C12002 cartridge filter. Hayward Swim Pure Plus T-15 SWG. Testing with TF-100 Kit. 2 speed 1.5HP Supreme pump. Dolphin Nautilus robotic cleaner
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    A 1 hp 2 speed pump would reduce your electricity use by 75% when running on low. It would work great to run on low for filtering and on high hp for other tasks. Actually, you could just change the motor and leave the pump in place.
