Thread: When should I get a new liner installed.
    Jul 2016
    Orand Park IL
    14
    I have a new to me pool that is about 12 years old. The liner is bleached out in the deep end, and really faded and bad looking above the water line. there are 9 or 10 patches, so it's time for a new liner. Does it make more sense to do the new liner at the end of this season, fill the pool up with new water, then close it for the winter, or should I close the pool with the existing liner, then get a new liner installed in the spring?
    bill
    21900 gal in-ground pool. 40' X 20' oval. 3' deep shallow end and 8' deep end. 1.5hp pump, cartridge filter, one chlorine reactor and another that I'm not sure of...it has a frog on it?
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,476
    Re: When should I get a new liner installed.
    I would do in when you would open the pool for the next swimming season UNLESS you are losing a lot of water and run the risk of it draining too much over the winter. I have nothing to base this on other that my gut LOL
    Apr 2016
    Kankakee Il
    39
    Just remember to look into it now and not the spring, builders will be swamped and it may be hard to find someone to install it.
    24' saltwater 8000 installed halfway in the ground, Hayward perflex ec40 hardpiped, Saltron retro xl swg, aqualuminator return jet light
    wjr75's Avatar
    Jun 2013
    IL
    836
    What we did for our replaster job was get quotes in September and then put down a deposit so we were one of the first jobs in the spring. The builders get booked up fast in the spring time.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
