Results 1 to 9 of 9
Thread: Did I buy the wrong sand filter/pump? Please help, experts. Thanks!
    Aug 2016
    Atlanta
    8
    Post Did I buy the wrong sand filter/pump? Please help, experts. Thanks!
    I have a small 15'x48" Intex Pool, Intex CG-28669 SWCG, and I just bought an Intex 3000GPH Sand Filter/Pump. I'm wondering if I should have bought the next size down, the 2150GPH version. I was told a larger pump/filter would be better for vacuuming. Here are the manual recommendations for media for the two (three):
    I was planning on using filter glass, but would have to buy two bags of glass with 3000GPH, vs 1 for 2150GPH (ok I'd be 5 pounds short, but figured I could use a little gravel in the bottom or sand, is that wrong?).
    So should I return the 3000gph before I open it and get the 2150gph, or keep the 3000gph? I don't mind spending the extra money, but don't want to buy the wrong thing.
    Thanks for the help in advance.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: Did I buy the wrong sand filter/pump? Please help, experts. Thanks!
    Bigger filter is always better... You will not regret it... 😊
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Also I will just put old regular pool sand like this one
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    120 pounds of it.. 😊
    Aug 2016
    Atlanta
    8
    Quote Originally Posted by Piolin View Post
    Really. You think the glass is just a waste of money?
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    I think old plain pool sand is all you need, but if you want to use the other it's up to you, I have excellent results with the one on the picture
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The general feeling around here is filter grade pool sand works fine (excluding rare situation where the wrong type of sand may have been packed in bags labelled as pool filter sand). Crushed glass and other sand alternatives are products looking for a market.
    LittleTagAlong's Avatar
    Jun 2016
    Amarillo TX
    119
    I would like to have the larger sand filter. Mine does an awesome job but being able to filter and vac in a shorter time would be great. And make sure you use sand packaged explicitly for sand filters or you could ruin your filter. I'm not an expert but I don't believe you should add gravel or rocks to the filter.
    AG, Intex 18' x48" Easy Set pool( =/- 5455 gal)
    Intex SF80110 sand filter & SWG ECO 7110, Hayward AquaCritter
    Well water, location is north Texas, usually up from late May to Oct.
    Taylor TF-100 test kit, TDS Digital Salinity meter and Taylor salt kit
    Apr 2015
    Angleton, TX
    3
    I have the EXACT same setup on a 16' x 48" Intex pool and am very happy with it. I don't have to backwash very often, only have to run the pump 6-8 hours, I installed a Hayward skimmer in the side wall of the pool and the pump runs a vacuum off the skimmer with no problems. Works for me!
    Intex 16 ft. x 48 in. above ground round pool.
    Intex 2800 gph 18" sand filter
    Intex salt-water chlorine generation system
    Newly installed, placed into service 6/9/15
    (back/knees still recovering...)
