Thread: Skimmer and pool level question
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    My PB plumbed in a 1" PVC pipe in the back of my skimmer as a water release to keep pool from over flowing. I don't know if this is common practice or not. I think the pipe is about an inch to low, and lets to much water out when splashing in the pool My question is can I plug it up and raise the pool level to within a inch of the top of skimmer? I know large leafs may not get through, but everything else will. Will this affect the skimming in any other way? I do realize that I will need to remove the plug before any rains, or I am out of town. Thanks!
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    Jul 2015
    Central Valley CA
    1,107
    Re: Skimmer and pool level question
    can you get to the back of the pipe where it comes out to drain? If so how about a ball valve there instead of a plug then you don't have to worry about the plug coming out.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    Pipe comes out in the yard about 10' from concrete. I'd probably run over the valve with riding mower. I have it plugged in side the skimmer now.
    Mark
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Yes, that is fine to do. Once the water level is close to the top of the weir the velocity into the skimmer will drop and it won't be as efficient skimming debris.
