Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: CYA levels
    Aug 2016
    Pahoa
    9
    CYA levels
    I have a problem with high levels of CYA, and I believe this is why I also have a problem with green algae. My CYA averages 80ppm which I have down from a high of 170. All my readings are in the normal range, PH 7.5, Alk 112, Calcium Hardness 270, average pool temp 82. Please note I live in a rain forest the water here is very soft and very clean, I average 100 pounds a month of calcium chloride just to keep my calcium hardness above 250, for a plaster pool. I've been keeping my FC between 2 and 4 with the average about 2.7, I want to know if I should keep my FC higher. I read somewhere on this forum a chart that gave FC averages based on CYA but I can't find it again. Any help will be greatly appreciated.
    In ground pool is 33' X 75' holds 110,000 gallons. I have 3 pool pumps that average 75-gpm through micron filters, 4 filters per pump, total of 12 filters. I have 3 chlorine feeders one on each pump. "This pool is 100% solar, the pumps only pump during daylight hours." It is an outdoor pool with no cover and I live in a rain forest.
    WalterWhite's Avatar
    Jun 2016
    Philippines
    15
    Re: CYA levels
    Hi Tmman,
    While I am no expert in the use of CYA it appears that the amount of FC you have for the CYA concentration is very low. Here is a link to the chart,
    Pool School - Chlorine / CYA Chart
    good luck
    Nueva Viscaya, Philippines, IG, 36cum reinforced concrete, ceramic tiles. Completed June 2016. Hayward kit: DE6020 filter with 6 way Vari-flow valve, Max Flow XL SP2707Z1M single speed pump, Chlorine Feeder CL200. Perimeter overflow skimmer to sump. Waterfall feature. In pool LED lighting. Test kit BlueDevil pH, TCl], FCl, Alk, TDS meter, pH meter. Filled from my own well.
    Aug 2014
    Northern IL
    4,615
    Re: CYA levels
    What type of "chlorine feeders" do you have?
    And, we would love to see a pic of your pool!!! So large and in the rain forest? Gotta see it!
    Dec 2014
    Santa Ana, CA
    523
    Re: CYA levels
    Quote Originally Posted by Tmman View Post
    How did you get your numbers? Just trying to understand how reliable they are.
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: CYA levels
    Pahoa, Hawaii?
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Aug 2016
    Pahoa
    9
    Re: CYA levels
    Quote Originally Posted by max2k View Post
    I use the colorQ pro 11 "DPD"
    Aug 2016
    Pahoa
    9
    Re: CYA levels
    Quote Originally Posted by MarianParoo View Post
    Aug 2016
    Pahoa
    9
    Re: CYA levels
    It's just a normal pool nothing fantasy.
    Dec 2014
    Santa Ana, CA
    523
    Re: CYA levels
    They look reliable- then as already pointed out your FC has been way too low for even your current CYA level. Basically with that CYA it's practically the same as no chlorine at all. You'd need to switch to liquid chlorine exclusively and SLAM the pool. Problem though your DPD kit has limit of 10 ppm. You might get around this with dilution as for SLAM you don't need 1 ppm resolution anyway.
    Aug 2014
    Northern IL
    4,615
    Re: CYA levels
    That is huge!!!! Thanks for the pics!
    NOT happy with 3 in-line chlorine tab dispensers. You are on your way back to a CYA of 170 because those tabs add CYA. Have you looked into a SWG or a stenner?
    Aug 2016
    Pahoa
    9
    Re: CYA levels
    I'm trying to get the board of directors to allow me to switch over to calcium hypochlorite tabs vs the trichloro s triazinetrione tabs we use now. But not having much success. FTR the reason I fight with high CYA is "I believe" we are near an active volcano and sometimes we get "vog" a form of acid rain.
    I'm not sure what SWG or stenner is. I would like to know though if you would share.
    Aug 2016
    Pahoa
    9
    Re: CYA levels
    Slam is something new to me. I super chlorinate the pool about every two weeks with calcium hypochlorite granules which are a headache to dissolve prior to putting in pool. I will put in a request to go with liquid bleach but the board will take its time in giving me an answer. In the meantime is my method worth the time and effort.
    Dec 2014
    Santa Ana, CA
    523
    Re: CYA levels
    you're putting CYA there yourself- check MSDS on those chlorinating tablets or the bottom of the PoolMath page (link at the top) where it says 'effect of adding ...' Don't blame volcano for everything
    SWG produces chlorine by electrolysis. Besides initial cost and possible maintenance it's the most chemically self contained system which in theory requires only water. In practice it requires some MA additions from time to time.
    Stenner is brand for peristaltic pumps which are used along with a timer to dose off liquid chlorine into the pool. You'd still need to store it somewhere as contrary to SWG chlorine is not produced by this system, only dispensed.
    Neither of them introduce extra chemicals to the water, that's why they're loved around here.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: CYA levels
    The bolded parts are related. If you went with bleach alone, you are probably looking at around 3-4 gallons per day based on bather load.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Aug 2016
    Pahoa
    9
    Re: CYA levels
    Thank you for the info I'll check into it. And yea I know I'm adding CYA and that's why I'm trying to find a much better method. Thank you again
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: CYA levels
    Dec 2014
    Santa Ana, CA
    523
    Re: CYA levels
    as was pointed out your method of using cal-hypo instead of tablets + liquid chlorine should be just what you need: you'll always be able to adjust proportion if your CH will raise too high. The cal-hypo / LC proportion depends on how much water you replace with soft fill water, in other words what is your say monthly CH 'loss'. I wish I had that problem .
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,183
    Re: CYA levels
    Do not use CalHypo tabs in that feeder. They are not as firm/compressed and dissolve quicker than the TriChlor tabs. They will just plug up those feeders. Plus, from a safety standpoint you should never mix chlorine types in any enclosed space like that feeder as it can have explosive results.
    Pool Chemical Explosion Accident Analysis and Investigation at chemaxx.com
    Pool Chemical Explosion - YouTube
    You have high CYA because Trichlor tabs are almost half CYA in the chemical compound. It has nothing to do with your volcano or acid rain.
    Support the site
    Aug 2014
    Northern IL
    4,615
    Re: CYA levels
    And to answer your previous question, you need to target at least 9ppm with the CYA of (80).
  20. Back To Top    #20
    Aug 2016
    Pahoa
    9
    Re: CYA levels
    Quote Originally Posted by Piolin View Post
    Pahoa, Hawaii?
    Yes
