Thread: Pentair Whisperflo Replacement Confusion
    Jul 2015
    Dallas, TX
    89
    Question Pentair Whisperflo Replacement Confusion
    My cleaner pump died and I'm looking to replace the whole unit with the exact same. It's a Pentair Whisperflo High Performance 1.5hp #011773. The label further reads "PMP WF-26 115/230V". When I called Pentair to determine if my current pump was still under warranty they specifically asked if "WF-26" was on the label. I had already given the 011773 part number so I'm not sure what this other info is and if/how it's relevant. This is where I need help. In shopping online I find the units are not necessarily labeled WF-26. Does this matter? Is the following unit the correct replacement?
    https://www.amazon.com/Pentair-01177...ct_top?ie=UTF8
    Thanks for your guidance.
    -M
    26K gal, in-ground, spa, Wet Edge Satin pebble, Pentair Intelliflo VS-3050, Whisperflo 1.5HP, Clean and Clear Plus 520, MasterTemp 400, EasyTouch PS-4 and ScreenLogic 2, GloBrite LEDs, DeltaUV D-20, Paramount Clear O3 and PV3, completed July 2014, TF-100, full sun, city water
    Jul 2015
    Dallas, TX
    89
    Re: Pentair Whisperflo Replacement Confusion
    Nobody knows?
    Nov 2015
    CA
    12
    I got the same pump which is 2HP single speed. I'm planning one getting a variable speed pump. I live in CA. The pump costs aroud 160 dollars every month. I'd say stay away with single speed pump.
    Jul 2015
    Dallas, TX
    89
    I have a single speed already. Just looking to replace it with the exact same model. Which is what I need confirmation on.
    Why not a single speed? I don't understand why I would want anything else - it's for a cleaner system.
    $160/mo?! Really?! Don't want to derail this thread.
    Thanks for your feedback.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    You are on the right track. A single speed pump is what you want for a cleaner. 2 speed is good for the filter pump to save money. No idea what WF-26 means. My two fave stores are Sunplay.com and INYO Pools. Maybe ask them.
    Jul 2015
    Dallas, TX
    89
    Talked to Pentair. The short version of what was explained is that the 'WF-26' matters; there are a few single-speed, 1.5hp Whisperflo models. The WF-26 is one of them. They, generically, refer to the WF-26 as an "up-rated" model.
    Maybe this will help somebody in the future.
