Results 1 to 7 of 7
Thread: Stains in vinyl pool
    Aug 2016
    Apple Valley, MN
    2
    I had trouble with dark stains on the bottom of our vinyl pool and the pool store suggested shocking and algaecide,which didn't help. It actually added additional areas of staining. Then I remembered muriatic acid and it was successful! When using muriatic acid, you should shut off your pump, so I do it in the evening. Also wear long pants, shoes and gloves, so you don't get any splashes on your skin and follow the manufactures directions on the container. Pour the muriatic acid around the pool perimeter, similar to when you add liquid shock. Keep your pump off for 12 hour or overnight and don't allow anyone to swim for 12 hours. In the morning, your stains should be gone. The pump should be started, vacuum the bottom and backwash. Muriatic acid can be purchased at Menards, Home Depot, Ace Hardware etc. for about $4.99 a gallon. I have a large 16' x 32' Doughboy pool with a deep end, so I have approximately 20,000 gallons of water. I added two gallons of muriatic acid. I hope this helps anyone with similar problems.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,321
    Re: Staining caused by chlorine shock.
    What did that do to your ph though when you added that much?
    And did adding borax or washing soda to raise it back make the stains return?
    (that's how I got mine)
    Dolphin E10 Cleaning Robot.
    Aug 2016
    Apple Valley, MN
    2
    Yes, I needed to add some PH up to the water. I posted too early. I thought I had the stains solved, but by this afternoon, I can see them returning. It's lighter, and less stains, but I can see it. I'm frustrated! Last week, I went to the pool store three times to have my water tested and explained my problem. I also showed them pictures. They had me treat for algae, but it doesn't puff up when I brush over it, so I didn't think it was algae. It also doesn't come off with your fingernail and smear. Two of the times they recommended adding 4 gallons of shock and algaecide. They also had me add a product for alkalinity. It seemed better, but then after three days away, the spots returned.
    16'x32' pool with deep end, 20,000 gallons, Diatomaceous Earth filter, Doughboy Poweline XP I pump, Nature 2 filter.
    Dec 2014
    Santa Ana, CA
    523
    Quote Originally Posted by Dreierav View Post
    I'm a little confused what are you after- I doubt anyone around here would be able to explain what was going on. If you'd like to get help then you're most welcome but it would require you to start from scratch: forget about what you ever heard and join this lively community of ppl enjoying their pools. Your call totally.
    What you'd need: reliable test kit first (TF100 preferred K2006 as a minimum), bunch of liquid chlorine, clear your pool of all chemical dispensers you might have there, put 2 gal of liquid chlorine in the water and add 1/2 gal daily after that until your test kit arrives and you can post your numbers.
    Please update your signature with pool/equipment details, post pictures of the problem and one more thing- start a new thread to avoid confusion.
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,321
    Dreierav, the forum can help you solve this, but you should start a new thread for yourself so it gets the focus.
    post some photos too...imgur.com is free to post photos.
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    Re: Stains in vinyl pool
    Wow.. your pool store has too much control over your wallet!
    You first need a real test kit of your own. TF-100 is suggested most often. TFTestkits.net is the place.
    I suspect they are metal stains from your Nature2 cartridge.
    Pool School - Metals in the Water and Metal Stains
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,772
    +1 -- Your system is likely causing the staining, but before using sequestrant to control metals, etc., post some pics and get a kit ( TFTestkits.net ) to take control of your sanitation methods so you can quit the Nature 2 unit and start diluting the possible stain source.
    In th mean time, if you keep your ph lower, eg 7.2ish, it may help the stains lighten.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
