How long to run pump and what RPM?
Titan7
768
Peoria, AZ
I have 1 week old newly filled pool. I am running 11 hours per day. 6am-5PM @2000 RPM and 5PM-7PM at 3450RPM. Spill over runs 30 mins per day. Is this too much? How many turn overs should I target per day?
Turnovers are not meaningful in residential pools. It only applies to commercial/public pools.
Usually you want to run the pump 24x7 for the first 30 days. 1600 or 1800 rpm should be fine. Are you brushing daily? Still getting plaster dust?
I run my pump at 1100 rpm to skim, filter and make chlorine with the SWG. Usually, 4 to 6 hours at 1000-1500 rpm is plenty. Some folks split it up 2 a couple hours in the morning and a couple in the evening for better skimming.
