Thread: Old Stain from Tool Rusting
    Jul 2015
    Oxford, MI
    43
    We've got these 3 stains on the bottom of our liner which look like a very large alan wrench was left in the pool for a while. This is our second summer in our new-to-us pool. We've only ever used the TFP method to take care of our sparkling oasis with never any problems. The previous owner... not so much.
    I don't believe this stain is from anything other than the tool rusting there. (Last summer I found the tool that fits this very pattern in the bushes.) I'm not sure what to do with it. Leave it? Try some vitamin C?
    Any suggestions?
    In-Ground pool: 10,000 gallon / vinyl liner /
    Hayward Vari-Flo XL sand filter / Hayward H-series heater
    TF-100 test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Old Stain from Tool Rusting
    Yes, Vit C should take care of it.
    May 2016
    Troy IL
    476
    That looks more like a tire iron to me. I'd check to make sure there aren't any holes around those rust stains, in case it was thrown in the pool and punctured as it landed.
    17,500 gallon IG Vinyl
    Pentair Tagelus TA60D Sand filter
    Pentair Challenger 1.5HP pump CFII N1 1.5A
    Taylor K-2006-A, Stenner 45MPHP10 auto chlorine feed
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,103
    You can get Vitamin C at the local dollar store. Crush a few of them and put the powder in a sock. Hold it on the stain for a few minutes. Check to see if it's having the desired effect.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    May 2015
    Fort Mill, SC
    179
    After the pump is off, put a small handful of Vitamin C pills right on the stain and leave it overnight. Those rust stains can take several hours to fade.
    20K gallon vinyl inground pool, Hayward Pro Series sand filter, 1 HP pump, Taylor K-2006
    Jul 2015
    Oxford, MI
    43
    Awesome!
    Definitely no leak - it has been like this for 2 seasons now (that I know of).
    Will pick up some Vit C and see where this gets me.
    Thank you!
    TF-100 test kit
