Results 1 to 11 of 11
Thread: chlorinating
    Jul 2016
    Hiram, GA
    35
    chlorinating
    My pool is finally balanced for the first time this year with the exception of chlorine which is between 7.5 and 10. I'm using Taylor K-2005. But, I'm ordering the better chlorine tester.
    My question is: Is there a minimum time to run your filter or a minimum chlorinator setting?
    I'm running for 10 hours a day @ 45%. I was running for 12 @ 50%. But, as I got my other things balanced the chlorine went up. So, I'm gradually bringing it down. But, is there a best way to do that?
    18,"x 36",IG, vinyl, SWG, Hayward Aqua plus with remote, Jandy cartridge filter, polaris 280, Hiram, GA
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    Re: chlorinating
    Your FC should be based on your CYA. What is your CYA?
    What size is your SWG?
    How many gallons is your pool? If you don't know, use pool math to estimate.
    The DPD test included in the K-2005 is useful to see if you have any chlorine, but as you've realized it is best to have the FAS-DPD kit to test FC because it is more accurate for FC and CC.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Dec 2014
    Santa Ana, CA
    523
    Re: chlorinating
    Quote Originally Posted by Pennypat View Post
    If you mean you got FC / CYA ratio where it's supposed to be according to The Chart then all you need is to adjust your SWG so it'd produce enough FC to compensate for daily loss. Running time depends on your pump type and local electricity prices. Under the same equal conditions VS pumps can be ran much longer without affecting your bill much. So I'd come up with desired running time first then adjust SWG output so it would maintain steady FC. If FC got too high I'd simply turn off the cell temporarily, let FC fall to the desired level and then turn the cell back on. If it falls too low I'd use bleach to adjust it back. Pump should be left running through this period as usual. Trying to 'catch' FC by decreasing SWG output might be too complex as you'd need to control both FC decrease and SWG output at the same time.
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
    Jul 2016
    Hiram, GA
    35
    Re: chlorinating
    CYA is 70. I'm guessing my pool is 25,000 gallons
    Aug 2014
    Northern IL
    4,615
    Re: chlorinating
    That is a high-ish volume. What is your water depth? Try the calculator at the bottom of http://www.troublefreepool.com/calc.html
    Dec 2014
    Santa Ana, CA
    523
    Re: chlorinating
    Quote Originally Posted by MarianParoo View Post
    the pool ain't small either I wonder if it is closer to 30k.
    Aug 2014
    Northern IL
    4,615
    Re: chlorinating
    My pool is 20x40 with an 8-1/2' deep end. I am at 27K calculated by my son with a physics degree...
    Dec 2014
    Santa Ana, CA
    523
    Re: chlorinating
    you're right- it's more likely 22k
    Jul 2016
    Hiram, GA
    35
    Re: chlorinating
    Using pool math calculator it is 27,900 gal.
    d
    Aug 2014
    Northern IL
    4,615
    Re: chlorinating
    Okay. Did you kind of account for the sloping deepend?
    Jul 2016
    Hiram, GA
    35
    Re: chlorinating
    No I just used the calculated. No physics degree here
