Results 1 to 15 of 15
Thread: What is the point in closing your inground pool?
    Jul 2016
    Hiram, GA
    35
    I'm thinking of leaving my pool open. I have some friends who leave theirs open year round. But, do you have to keep the pump running daily, like in the summer? And, keep the chemicals balanced in the same way? Is the point of covering just to not maintain it? As you probably guessed, this is my first experience with a pool.
    18,"x 36",IG, vinyl, SWG, Hayward Aqua plus with remote, Jandy cartridge filter, polaris 280, Hiram, GA
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,427
    Re: What is the point in closing your inground pool?
    I've always kept mine open year round and maintain proper balance.
    In the winter months I only run the pump on saturday for a few hours and vac any debris on the floor.
    That's about it for off season.
    Chlorine usage is much lower during that time as well.
    For some it could be a concern if they are in constant freezing climate though there
    is freeze protection on some pumps.
    Mostly though it seems like it would be one less thing to deal with for those that close each winter.
    Dolphin E10 Cleaning Robot.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,748
    Mine stays open. I switch to bleach for chlorine when the water temporarily drops below 70. As mentioned, FC usage is very low when the water is cold. Pump runs a few hours a day to skim.
    Jul 2013
    Lelystad, The Netherlands
    60
    Depends on the climate and the area you live in.
    I live in The Netherlands, and my backyard has very high level of groundwater. Closing (and emptying) my pool would result in serious risk of groundwater pushing between the concrete wall and the liner. Our winters are not extremley long and col, so keeping the water in motion should be enough to prevent the water from freezing.
    As soon as the outside temperature reach 2 degrees celcius I let my pump kick in until it reaches about 3 or 4 degrees.
    I was told that below 15 degrees celcius, algae can't live so when the water is below 15 I stop maintaining chlorine level (or any chemistry level at all).
    40000 liter in ground vinyl pool with SWG : http://www.troublefreepool.com/threa...he-Netherlands
    May 2016
    Bristol, CT
    29
    I just moved to CT (heading into my first winter here, ugh). I imagine keeping mine open isn't an option....unless the pump is running 24/7, freezing would be a big risk. Maybe even with it running......
    27,000g, 3'-9' IG; Freeform Concrete; Hayward 1hp SuperPump; Hayward Sand Filter S244T
    Jannylee53's Avatar
    Mar 2015
    Manor, Texas
    661
    We keep ours open. Slow the pump down. Run it less. Vacuum less etc. we do watch chemicals still As mentioned by others not much required.
    New pool build in Manor, Texas. 2015. 509 sq. feet; 31'6" x 19'10". Sunshelf & bubbler and waterfall sheer. Gunite inground pool. Pentair Intelliflo VS-3050 pump; Filter: Pentair Clean & Clear 420 Cartridge; Inline chlorination w/UV Sys;Lighting:Pentair IntelliBrite Color LED 120V;Cleaner: KK Racer w/booster.Bench/ledge;limestone Coping; Verona Tile 562 Decking
    May 2015
    Fort Mill, SC
    179
    I close mine. Now when it's midnight in January and there is an ice storm and the power is threatening to go out, I sleep like a baby. Also I don't have to make any bleach runs from October through May and don't have a pump using electricity every day. The water change I get from lowering a foot or so is helpful as well. I did leave it open one year, and have a freeze protect circuit installed.
    20K gallon vinyl inground pool, Hayward Pro Series sand filter, 1 HP pump, Taylor K-2006
    JoyfulNoise's Avatar
    May 2015
    13,446
    Here in southern Arizona we don't know what you mean by "close the pool" ...
    Matt
    May 2015
    katy, tx
    31
    I'm with joyfulnoise on this. Here in Houston, we could throw the heater on for a few hours and be swimming in November or December. Spa is always fun as well. We built a bigger spa for the kids for that reason. It really irritates my in laws in Connecticut and Massachusetts when we send them pictures of us swimming in December.
    16,500 gallon in-ground pool and spa with Quartzscapes Midnight-blue and pretty sparkles
    Aqualink RS with PDA
    Jandy Pro Series Plus HP 2 HP 2 Speed Pump
    Jandy CV460 Cartridge Filter
    May 2015
    13,446
    Quote Originally Posted by downtfish View Post
    My brother "has to visit" his in-laws in St Louis every Christmas (you know who makes that decision ). Last year I texted him a picture of all of us sitting in the spa with Santa hats on with the text "Wishing You 'Warm' Xmas Greetings!".... he texted me back with the middle-finger emoji. Hehehehe
    Matt
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    I never close the pool. Once it gets too cold, November ish, I run the pump an hour a day with the Polaris. The chorine demand drops to a cup every few days....
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Jul 2016
    Hiram, GA
    35
    I'm ready to start slowing down my pool pump. I live in GA and it is around 83 everyday now and the pool is about 70 degrees. Could I go ahead and start running my pump less time. I run it for 8 hours a day now which is what I was running it in the summer months. Do you just trend down the time you run it or wait until it gets really cold. It does get freezing and below here. But, usually in Jan./Feb. By March it starts getting warm again. I have some sort of freeze protection on my pump. But, I guess I need to read up on that. I don't know if it is automatic or not. (first time pool owner).
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,195
    PennyPat- I haven't closed my pool since moving in. Nor do I plan too. What you plan to do sounds just right. I don't have the freeze protection thing on my pump, though, so I do it myself if I hear about a cold night.
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    May 2016
    Troy IL
    482
    I'm kind of with C3Cl3N3O3. I don't want to worry about power outages and freezing temps from ice storms or something of that nature. I've been without power for several days due to an ice storm before.
    So at some point this year, I'm going to half close my pool. I will winterize my plumbing and pump/filter, and plug all lines. But I'm going to leave the pool uncovered. I covered it last year, and I'd just prefer not to if I don't need to. I have no trees to dump leaves in it, and our safety fence keeps most debris out. If anything does get in it I'll vacuum it with a leaf vacuum that uses the garden hose for power.
    My water is 65 and already using quite a bit less chlorine. I'm hoping it'll soon be using so little I'll hardly ever have to add chlorine.
    17,500 gallon IG Vinyl
    Pentair Tagelus TA60D Sand filter
    Pentair Challenger 1.5HP pump CFII N1 1.5A
    Taylor K-2006-A, Stenner 45MPHP10 auto chlorine feed
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,087
    I would hazard to guess that most folks in the more southern climates don't close their pools. I dont close mine.
    I would say you're on the right track. If the temps get down close to freezing, just make sure your pump is running and you'll be fine.
    Divin Dave,
