Thread: testing tubes ( are there tubes for FC that go higher than 5 or 6PPM?
    May 2015
    Fullerton, CA
    635
    Just wondering as aren't we guessing if the tube stops at 5 or 6?
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: testing tubes ( are there tubes for FC that go higher than 5 or 6PPM?
    Not if you have the FAS-DPD test that we recommend that is part of the TF-100. That can test up to 50ppm and is an integral part of the TFP philosophy.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    You have a tf-100 and it has the FAS/DPD test supplies in it.
    May 2015
    Fullerton, CA
    635
    Yes, I do have the TF-100. I have not done a FAS/DPD test yet. Should I be doing this if FC PPM is greater than 5. I guess this is the right test to run over 5ppm. Thanks!
    SW Indiana
    9,199
    Quote Originally Posted by Titan7 View Post
    Yes, that's what you need for higher numbers.
    DFW, TX
    24,483
    Right on, it'll measure up to 50ppm.
