Thread: Will a robot cleaner be able to climb onto and clean my baja shelf and steps?
    May 2015
    Fullerton, CA
    636
    My Baja shelf is pretty large and is 18" deep. I am thinking rather than mess with the suction cleaner I may just go with a robot. What's the best one for under $1000.00?
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,757
    Re: Will a robot cleaner be able to climb onto and clean my baja shelf and steps?
    It should in 18". My shelf is 12" and the robot will not go on top of it. Any neighbors have one you can try?
    I consider the Maytronics (Dolphin) cleaners to be the best. Some have reported getting the S300i for right around $1000.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    May 2015
    Fullerton, CA
    636
    Nobody does, all suction cleaners. I may check out you tube to see.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,757
    You're welcome to try mine if its worth the trip to Rivertown
    -Brian-
    POOL BUILD
    May 2015
    Fullerton, CA
    636
    I may take you up on that in 30 days after plaster is cured, thanks!
